tacho problem
From Port Douglas. QLD
hey eveyone,
heres the problem.
In neutaral the vdo tacho works perfectly, but once driving after say 2000-3000 revs
its stutters, climbing and falling with a jerky motion.
checked wiring and searched on here with no luck
engine is l20b with electric dizzu.
cheers
Posted on: 2013/3/24 10:19
1200 ute
ca18det
Re: tacho problem
From Townsville, Qld
Check earthing points, check voltage regulator sect. I've never found it an annoying issue I just accept that's what it does
Posted on: 2013/3/24 22:27
Re: tacho problem
From Adelaide
Also check the ignition condenser (capacitor) if fitted.
I had an issue like this that I never resolved in an old car. It's noise in the ignition circuit so if you can fix that it'll go away. A friend with an oscilloscope might be able to help if the other checks don't fix it.
Posted on: 2013/3/24 23:42
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
Re: tacho problem
From Snohomish, WA USA
Pull the leads of the capacitor by the coil and fit a flat fuse to them. See if that fixes your problem. If so, leave it that way.
Posted on: 2013/3/25 4:22
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
