« 1 (2)
Re: What pound springs on rear coilovers in 1200 sedan
From Narellan,Sydney
Yeah he was Thinking around the 200 mark.going get 200 and see how they go.then ill know exactly.lucky there not to expensive
Posted on: 2013/3/28 10:55
All stainless steel-mild steel Sheetmetal and tube work
All types of welding
Custom metal polishing
BSA custom fabrication 0415 904 474
From windsor, sydney
hi datrotor , we use 150 or 175 on rx7 racecars so looks like your close but you will have to try a few different rates and see what it likes . the position of the instantanious center of the rear 4 link arms and in turn the antisquat/squat ratio will need to be concidered as well , is this car registered with a 13b turbo?
Posted on: 2013/3/29 5:11
WARDMAN ENGINEERING
CNC machining
Race Car Fabrication
Suspension, Brake, Drivetrain modification
TIG welding of all metals
0413 595 627
Yeah that's A fair point I'm going to wack in 200 and see how it likes
it then ill go from there wards.yes it's registered with the 13b turbo
Posted on: 2013/3/29 6:28
awsome, they wont pass that now , dont let it run out of rego,
Posted on: 2013/3/29 10:19
WARDMAN ENGINEERING
CNC machining
0413 595 627
Yeah I know mate but the rta laws have changed now there is no capacity limit as long as brakes, suspension etc is all up to the engine specs
Posted on: 2013/3/29 10:36
« 1 (2)
