Re: Strong gearbox
Posted on: 2012/8/23 5:39
Re: Strong gearbox
From 25 Division St Ste 200, San Francisco, CA 94103
Guys what about the mileage, how much it gives?
Posted on: 2013/4/1 5:47
custom made to order rugs
Re: Strong gearbox
A typical Datsun five speed gives about 20% better fuel economy at 60 mph (100 kph). An almost no difference at 40 mph.
Posted on: 2013/4/1 5:59
Re: Strong gearbox
From WA perth
where do you get one of them from , the first 1
Posted on: 2013/4/1 6:29
Re: Strong gearbox
The first photo shown was a Borg-Warner T5. Get one at the wreckers. It doesn't bolt up to A-series engines, so make an adapter.
Posted on: 2013/4/1 6:51
Re: Strong gearbox
From WA perth
not the box ,I mean sequential shifter,plus what cars the box comes out of.
Posted on: 2013/4/1 7:36
Re: Strong gearbox
From WA perth
did you know that you can get a t50 box rebuilt with any ratios you want. a friend of mine being racing a westfeild with the same box for 4 years an wore it out,motor ca 18 around 190 whp
Posted on: 2013/4/1 13:00
Re: Strong gearbox
the Nissan 71C sequential shifter is from www.japaneseautocentre.com.au but also avail from Jpn Im sure.
The T5 can be A seriesed using a 5mm adaptor from box to the auto bellhousing, machined input shaft and ford escort type clutch to A series flywheel and ford Hydro release bearing. T5 also has seq shifter but never seen the results of that compared to the 71 series box.
T50 boxes are pricey for the close ratio gearsets while 71c and B boxes are 1400aud from Japan but 71 box needs adapting. However look up the vid of Sykines A12 turbo at PI and hear it upchange on the straight simply awesome. Can only imagine those Z cars devastated if he had an extra 400cc x 1.7 = 2.7 liters closer to big bore L28 & no noise limits.
here is another Ikeya with 71 series box
http://www.youtube.com/watch?v=k2mGfeP5pj4
Posted on: 2013/4/1 13:15
« 1 2 3 (4)
