« 1 (2)
Re: A15 Electronic Ignition conversion.
From Trinidad and tobago
I'm gonna make the bracket.with the EI now what's the best spark plug to use?I use BP5ES.
Posted on: 2013/4/5 2:46
'71 Four Door Sedan.
Street Sleeper!
STILL LIVIN' THE 70'S LIFE !!
BP5ES is perfect. Or you could go with BP5ES-11 which has a larger gap.
Posted on: 2013/4/5 21:08
Ok so now i have the gear on and dizzy sitting in the block.What postion should the dizzy be spot on to be timed properly?
I also have 8mm plug wires to go with that.
Posted on: 2013/4/8 21:21
Street Sleeper!
Why not use 9mm plug wires?
See Ignition Timing, section "Initial Timing"
1. Turn engine until old distributor points to #1 plug wire
2. Remove old distributor
3. line up teeth on new distributor while installing
Posted on: 2013/4/8 21:33
Its a new distributor am gonna use i didnt get any with the engine is it ok to line up as normal then continue
Posted on: 2013/4/9 2:36
Street Sleeper!
Yes, time it like the stock distributor.
This is 5 degrees BTDC. But it could be for #1 cylinder or #4 cylinder.
If it backfires when attempting to start, rotate the plug wires two spots over and try it again.
Posted on: 2013/4/9 2:41
« 1 (2)
