Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
what goes where on a CA18
demacoz
Posted on: 2013/4/6 0:03
How many times have you looked at all the piping and stuff on a CA18 and said "What tha?"
Found a write up that helps heaps for those trying to figure out how to put it all back together - it's for a FWD Pulsar but you'll quickly get the gist http://jasonborowiec.com/ca18det/plum ... g/pluming_wiring_low_res/
#2
Re: what goes where on a CA18
Posted on: 2013/4/6 0:07
What! Ca s were not standard in Datsun 1200s? Wtf.
#3
demacoz
Posted on: 2013/4/6 0:49
I think they were a factory option ....
Or so it seems these days :)
#4
D
Posted on: 2013/4/6 4:05
Good post Demacoz will need this for the turbo connections yet
heading towards LPG like sl33pe & another 1200 sedan cadet dude to help rid the messy pollution gear at least. http://www.youtube.com/watch?v=Cu9LhchTZ54 http://www.youtube.com/watch?v=s97v9RewMrg
#5
shaun
Posted on: 2013/4/6 12:17
Sleepe made 215kw atw on lpg was was pretty much a standard ca apart from a ka24 throttle body and a set of tomei proncams, Joel's is the ca sedan in the first video and he got converted to lpg after going in my ca18det 120y wagon , people underestimate lpg , its so easy to set up and tune and there is no need to retune when you want to upthe boost, it uses the standard computer for spark and that's it, its definitely a cheaper and easier option
#6
D
Posted on: 2013/4/6 13:24
Its good to know standard ecu can be run without the injector side working would love to know the kind of Impco mixer you guys used.
#7
datsik
Posted on: 2013/4/6 13:55
"Its good to know standard ecu can be run without the injector side working" a ecu will work with many outputs not connected! an ecu just needs the inputs to work and all outputs are optional.
#8
Posted on: 2013/4/6 20:00
Not universally true for all ECUs: "an ecu just needs the inputs to work and all outputs are optional". Some will trigger warnings or limp-home-mode if certain outputs are out of spec (or not connected).
The factory Datsun/Nissan ECUs are good stuff. demacoz, good information. Added to our CA-Series Engine Swaps article.
#9
DON_1200
Posted on: 2013/4/6 21:56
awesome thread guys, really good info... this will surely be of use to any inc mysef very soon.. thanks
#10
shaun
Posted on: 2013/4/7 0:53
We used an impco 200 , with the ecu you only need to power up 2 wires, the one for the coils and the cas wire
