« 1 ... 5 6 7 (8) 9 »
Re: Toying with oot
From Melbourne AUS
your standard datsun speedo cable will fit into the rx7 gearbox and should be just long enough.
if not i believe 120y is longer. you will need a reduction box though to make the speedo read accurate
which you can get from speedscreen like unfam said
Posted on: 2013/4/10 11:05
1973 B110 A12
Re: Toying with oot
From Adelaide Hills
Awesome. My gearbox is too far back for stock 1200 cable. The rx7 one looks like I could make it fit. The dash end isn't threaded tho so bit of glue and were done, haha. Nah I'll look into the reduction box, speedo never read correctly anyway but if its consistent and not wound all the way off then I could just make a new face for the dial.
Posted on: 2013/4/10 11:35
Re: Toying with oot
From MOOROODUC. Victoria
that's it - thinking outside the box (or in this case the cable)
Posted on: 2013/4/10 13:15
Re: Toying with oot
From Adelaide Hills
Took the ute for a 110km round trip to pick up a new air conditioning unit for the house on Saturday. Didn't miss a beat. Soo much better on the freeway having five gears and power.
Real stocked with it, got stuck in traffic at road works on Green Hill Rd for a good 15min and the temperature stayed under 87degrees. Floor got a bit hot tho where the exhaust passes under foot well but nothing to worry about.
Posted on: 2013/4/14 12:41
Re: Toying with oot
so you should be stoked!
I have an A14 SC EFI and the extractors pass closely by the passenger side foot well and that gets bloody hot!
Have you had any attention to sell it yet? Its a shame, its such an awesome little car!
Posted on: 2013/4/14 12:50
1200 Ute - Mild A12
1200 Ute - Donor Shell Sold
1200 Coupe - A14 EFI SC
Re: Toying with oot
Hot feet, bonus in winter
Posted on: 2013/4/14 13:12
Re: Toying with oot
120Y speedometer cable is 200 mm longer than B110. And 180B (610) cable is even longer than that and also compatible.
Posted on: 2013/4/17 7:23
Re: Toying with oot
From Adelaide Hills
No enquiries yet. Got a fair list to get done before its ready for sale.
Ordered a new ignition switch and setup good relays for all the electrics. Made a noticeable power gain (it melted the fuse holder on the temporary ignition wiring).
Also found a way to fit the Mazda air filter and box.
Still have to fix a little oil leak, tidy up gauges, make a better hydro handbrake, weld diff, speedo, carpet, door cards and the rest.
Posted on: 2013/4/21 8:11
Re: Toying with oot
From Adelaide Hills
Definitely getting better, fixed the leaks and finished the wiring today. Moved the engine over a few millimeters so it doesn't touch the steering box when cornering hard. Made an extra exhaust mount (I suck at making exhausts. First it was too loose, then it snapped a mount because it was too tight. Hopefully now its good enough).
Wish I had the funds and time to do things top notch. Would love a nice new exhaust system and Webber setup. Maybe a 2-way and half cage.
Posted on: 2013/4/23 11:34
Re: Toying with oot
From Adelaide Hills
Yes officer, stock 1200 engine bay.
Posted on: 2013/4/25 10:19
