Browsing this Thread:
need advice on datsun gx 2l turbo setup
Not too shy to talk
Hi. I have a dutsun gx coupe and i am planing to put in a toyota 3sgte with a cressida r21 gearbox. My only problem is dont know what differential to use for the amount of torque?
Posted on: 2013/4/11 7:46
Re: need advice on datsun gx 2l turbo setup
3S-GTE engine makes 190 lb-ft in stock form in the early Celica.
The H165 differential can handle that, for example a Datsun 1200 ute diff. Or a BW68 from an aussie-assembled 120Y.
Posted on: 2013/4/11 8:10
Oh, looks like the Caldina makes up to 240 lb-ft. For that you should go stronger than H165, maybe the BW78 or a Datsun H190. See Rear Axle Swaps.
Posted on: 2013/4/11 8:18
Not too shy to talk
Ok tanx..do you think my engine and gearbox setup is fine. Or would you prefere someting els
Posted on: 2013/4/11 8:34
From Western Australia
I'd prefer something nissan/datsun
Posted on: 2013/4/11 9:37
1200 Sedan SR17VE + TURBO (Borg Warner twin scroll), 6 Speed, Brembos, Autronic SM4 ...coming together slowly.
Stanza rally car mostly ex works = FIA head, 50mm Mikunis, option one, works diff, 4 pot FIA calipers and vented disc all round, enkies, h...
Not too shy to talk
Yes i also had in mind the nissan sr20det but they are quit expensive
Posted on: 2013/4/11 17:24
Yes, the 3S-GTE is a fine engine, similar to SR20VE. I do not know much about Toyota gearboxes.
Posted on: 2013/4/12 0:56
Beautifully strong engine especially the beams version but unfortunately too heavy and wide style head much like the mistu 4g63 but head from 5S-FE with porting has shown it is a superior later style head with narrow valve angle making it narrower and higher angled port design much like the late 4a-fe & 7a-fe heads on 4age blocks for more power than the GE wide angled head versions.
having said all that where are you and cant you get the ga16de engine? they can be taken to 1.8 using qg18de crankshaft or just use the qg18de with ga16de head for more compression if NA or boost it for numbers a tad short of sr20det when ported and right cams are chosen but lighter and more compact size not to mention the Nissan name which makes your coupe proud. PJZ peter is racing his 1.8ltr ga16de and says its as light as the a15, just as compact and amazing mid range.
http://www.flickr.com/photos/10498579 ... in/set-72157601174332356/
http://sr20nation.com/ga16forum/showt ... RWD-conversion-for-GA16DE
http://www.britishv8.org/Other/NormanRest-Sprite.htm
rid the dizzie with cheap megajolt jnr like DDgonzales pics on his gallery and use the non vct head for even more compact dimensions.
Posted on: 2013/4/12 2:31
Edited by D on 2013/4/12 2:59:26
Yes, it is heavy just like the SR20DET
SR20DET 250 HP weight 328 pounds
3S-GTE 240 HP
For that you get factory reliability. Or you could go with a highly stressed "built" GA16DE with same HP but without factory reliability. Obviously the GA is a better performance choice (lower weight is always better for performance).
In USA we can get 3S-GTE where for less $$ than SR20DET -- $1700 for low-mileage 3S-GTE with ECU.
Posted on: 2013/4/12 4:36
Not too shy to talk
ok tanx. Do any one know what disk brakes to use in front and rear.have a look at this setup
http://www.nissanownersclub.co.za/forum/viewtopic.php?t=5419
but where wil you find that laser cuted mounts?
are there maby an easier convertion..?
or maby an nother diff with disk brakes alredy fited ?
Posted on: 2013/5/1 20:02
