« 1 (2)
Re: speeaddic 73' restore and mod
From sunshine coast
So my 1mm oversized pistons showed up today ....but there flat top and the old ones were dished ....will this complicate things or should I just shave less off The head ?
Posted on: 2011/7/20 9:47
73 1200 Ute
75 125 CR
84 250 CR
89 500 ktm
07 250 CR
vintage mx ....
From Near Bundaberg QLD
how much do you plan to shave off the head? if you're running a standard cam and you're not going to shave too much off you could just run premium/98 ULP if you have any issues with pinging.
Posted on: 2011/9/18 12:49
Thanks, Sam-U-El/Racer135
4 utes, 1.5 sedans, 2 120Y sedans, 1 C120, 1 1600 sedan, all look like or are wrecks
From sunshine coast
Plan on going to 10.5:1 compression ratio ...means I have to shave around 1mm off .
I'm getting the cam re-ground ......I didn't have any problems before it came off the road ..I'm hoping to tune it to run it on E85
Posted on: 2011/9/19 3:52
73 1200 Ute
75 125 CR
84 250 CR
89 500 ktm
07 250 CR
vintage mx ....
i've got a pair of dellorto dhla40's which are set up for methanol i'd like to swap for a pair of unleaded dhla40's from an a-series
Posted on: 2011/9/19 9:25
From sunshine coast
I am a massive fan of methanol. :D. My 1975 125 cr runs on it HAhahah
Maby one day ill be able to build a methanol burning A series :)
Posted on: 2011/9/19 9:38
73 1200 Ute
75 125 CR
84 250 CR
89 500 ktm
07 250 CR
vintage mx ....
well, you are building that engine with 10.5:1 compression ratio *nudgenudge*
I was going to chuck some flat tops in one of my a12's and a cam and use these dellorto's with some E85, pretty much the same setup as my mate had in his blue sprint coupe. He told me the carbs from the meth 1L should work fine on an a12 running E85.
Posted on: 2011/9/20 9:37
From sunshine coast
Hahahah sorry mate already got kiehin fcr pumpers Hahahah ..more than adequate
Posted on: 2011/9/20 9:44
73 1200 Ute
75 125 CR
84 250 CR
89 500 ktm
07 250 CR
vintage mx ....
From sunshine coast
hi all its been a while.
i ended up buying a14_stroker's 12a rotary coupe which was awesome until it died last month
i have made some progress on the ute and now have a fresh engine .
i got the cam reground for a 7800 rpm peak .
1 mm oversize pistons 11.8:1 compression ratio
triple cut valves Tomei double valve springs and tomei light weight push rods
and heap of port work :)
the old man and i had a go at building some custom 4-2-1 headers. they turned out quite nice
here is a vid of it runnimg . no exhaust atm just headers :P
http://www.youtube.com/watch?v=eI9C_xyLsa8
Posted on: 2013/4/16 4:19
73 1200 Ute
75 125 CR
84 250 CR
89 500 ktm
07 250 CR
vintage mx ....
From sunshine coast
Posted on: 2013/4/16 4:34
73 1200 Ute
75 125 CR
84 250 CR
89 500 ktm
07 250 CR
vintage mx ....
From Hawaii, USA
nice work!
Posted on: 2013/4/16 23:57
« 1 (2)
