This car loves me.
Yesterday I took it out for a spin. Driving down the road I look in the rearview mirror and notice a nice smoke screen laid out. I pull over and notice oil all over my exhaust just smoking. Nothing showing forward of the driveshaft so I'm guess rear Tranny to Driveline seal just went out. Was only a mile from home so I drove it.
Drained the gear oil out and pulled Driveline off. The seal didn't look even all the way around so I'm assuming that's the problem. Picked up a seal and put it in only to find out that I couldn't get the Driveline back in because I guess if you tap the seal in as far as it will go instead of just flush, the seal interferes will a metal ring just on the other side of the seal so, driveshaft won't fit. Had to order another one. Will be here at noon.
Oh, and also, I had to replace the front main crank seal on the motor the other day. Had a small small but noticeable leak. When I built the motor, I tapped that one flush and apparently that one has to be all the way in as far as it will go. Go figure.
More tunning to do with carbs and new spark plugs.
So I'm guessing all will be good soon.
