Re: longer lower control arms
Stanza uses same LCA as 1976-up 1200 ute (the H85/W50/W58 transverse link), which is why they measured the same.
Posted on: 2013/4/16 23:30
70mm too long for me. I remember some one had offset bump steer spacers that pushed the ball joints about 15mm further out.
Any one know these ?
Posted on: 2013/4/18 3:42
Posted on: 2013/4/18 3:51
That's them. Do they fit late Ute ball joints?
Posted on: 2013/4/18 3:55
The ball joints fit to the knuckle arms. Has nothing to do with the spacers.
These Roll Center Adjuster spacers are adapters -- bottom bolts to 1200 knuckle arms, top to AE86 struts.
Would be easy to machine out of aluminum.
Posted on: 2013/4/18 4:08
Yes but I would like off set ones to space the strut sorry not the ball joint further out... That would increase track too
Posted on: 2013/4/18 4:10
The ones in the photo i believe are offset for the strut -- for negative camber.
Posted on: 2013/4/18 4:13
Ok but where to get them as they look like they would increase track width too
Posted on: 2013/4/18 5:10
From Sydney
What are you wanting to achieve as a result of longer LCA's. Are you wanting increased track or increased negative camber or both?.
Posted on: 2013/4/18 5:29
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
Yes, longer control arms will increase track AND provide negative camber. It does both unless you modify the inner fastening points on the crossmember.
You can have a machinist fabricate the roll center adjusters.
Posted on: 2013/4/18 5:34
« 1 (2) 3 »
