« 1 2 (3)
Re: Datsun 1200 coupe project
From Snohomish, WA USA
Sweet Motor!!
Posted on: 2013/4/19 20:18
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
Not too shy to talk
From South California, USA
For the front suspension I used the 280z struts and cut them so I could use the shocks from an MR2. And for the steering knuckle I used one from the 510 since I adapted a rack & pinion from a 240z. A lot of work but finally got it to sit in, I had one of my buddies make an extension for the passenger side since the rack & pinion bar on that side did not reach the knuckle. I also had to shorten the steering column, ended up using one from a 240z.
Too much mod, its going to end up being a 1240z hahaha.
Posted on: 2013/4/22 18:13
Not too shy to talk
Thanks for the comments.
And the ring and pinion from nismo for that type of diff is 450$, so im looking around to see if i can get it cheaper from someone or find it.
Posted on: 2013/4/22 18:15
You can get a good used H165 4.11 Ring & Pinion set from Australia for $250 including shipping. For better acceleration go with a 4.375.
Posted on: 2013/4/22 19:31
Not too shy to talk
Yeah i think ill search one in australia regardless of shippining. i would like a 4.11 since i dont think ill be racing a lot. Gives me a little of both worlds.
Thanks a lot.
Posted on: 2013/4/22 19:37
« 1 2 (3)
