Re: SU Draw Through Turbo Carbie Help
Yes, there is a service kit -- but it is very rarely needed.
Contains
* new 'needle & seat' valve for the fuel inlet
* new fuel bowl gasket
* new dome gasket (which rarely goes bad)
* new gaskets for the fuel lines
It is doesn't leak, don't fix fix it! Sometimes they come with new oil dampers, but unless it is gummed up there is no need.
SUs don't have jets. They have one needle valve and one dome spring per carburetor. Start with the needle & spring that's in there. After seeing how it reacts, then change accordingly. Both the Rover 3.5 and the A12 like an air/fuel mixture of about 14:1 and the SU is very flexible. My guess is the damper oil viscosity and the spring will be most important as they have a large effect on sudden throttle openings and closings.
Posted on: 2013/4/27 7:01
Subject Poster Date
     SU Draw Through Turbo Carbie Help BeeJJ 2013/4/27 6:54
       Re: SU Draw Through Turbo Carbie Help ddgonzal 2013/4/27 7:01
