« 1 ... 37 38 39 (40) 41 42 43 ... 96 »
Re: Super Bee KA24DR Mod
From Snohomish, WA USA
No. No new block. Didn't go in the garage tonight.
The front seal leak should be fixed. Tranny leak I guess we'll find out.
Posted on: 2013/4/22 6:12
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
Sleeve should work well there's more than one way to skin a Ka(t)!
Posted on: 2013/4/23 4:21
There's more than one way to Sleeve a KA(t)!
Sleeve worked so no leak in the front. I still have transmission fluid leaking out the rear tranny seal. I left the shift boot off in the car so I could look down at the driveline while driving it. No fluid came out of the shifter. May have to take the darn Driveline out again.
Repair Sleeve before and after. Used the Permatex Green to glue it on. The Green stuff is made for bearings
jpg  IMG_20130422_084536_367.jpg (190.72 KB)
39_5176c4abc4318.jpg 808X455 px
jpg  IMG_20130422_092017_386.jpg (168.48 KB)
39_5176c4bb3133d.jpg 816X459 px
Posted on: 2013/4/23 18:13
Edited by datsa73 on 2013/4/23 18:28:59
Edited by datsa73 on 2013/4/23 18:34:06
Edited by datsa73 on 2013/4/23 18:37:14
'73 2 Door Sedan
Long story short. Not racing tomorrow. Still have rear tranny seal leak. Guessing now after talking with Oliver at Z Specialties (who happens to be my neighbor) that my driveline is now 1 inch to short due to my engine swap. Tranny mount did not move forward or aft but tranny tilted up a little in the rear. Don't know how that happened but I'm now not getting enough of a purchase on the tranny output shaft. So, I may be getting movement in my driveline. So, Monday I'm taking my driveshaft down to Northwest Driveline to get it lengthen 1 inch.
1 inch is going to cost me $150! Rats.
I'll start there and see if that fixes the problem.
Posted on: 2013/4/28 1:19
Edited by datsa73 on 2013/4/28 16:33:51
'73 2 Door Sedan
Can you move the engine back one inch? That would be even better for traction.
I would check the driveshaft length before concluding that is the problem. Unbolt it from the flange and see if it goes in more than 1". It might be fine.
Posted on: 2013/4/28 1:44
Ah ha! The,real reason you moved up by the lake, you were stalking the a specialist for expert advice free! Busted.
Posted on: 2013/4/28 1:46
No room and to much work. I'll pay the $150.
Posted on: 2013/4/28 1:50
'73 2 Door Sedan
On the plus side you know will be balanced too
Posted on: 2013/4/28 1:55
Yes. I'm just hoping I didn't screw up the splines or the yoke while running it to short.
Posted on: 2013/4/28 2:35
'73 2 Door Sedan
How do you know it is too short? Oil leak can be caused by several things including a worn slip yoke.
Posted on: 2013/4/28 2:57
