« 1 ... 7 8 9 (10) 11 »
Re: Turbo manifolds- new model, new pictures up.
Quite a regular
From Ballarat Vic
I think he means like this collector on the manifold I have just made
jpg  Business Notes_01.jpg (82.35 KB)
15895_517fb7d3a4868.jpg 792X1102 px
Posted on: 2013/4/30 13:26
Nice workmanship for an equal length Datsgold.
Due to the firing order 1-3-4-2 using a divider
its best to pair up 1-4 and 2-3 as Simon says.
Posted on: 2013/4/30 15:15
Looks just like the one on page 7, great work. Looks like you've spread the two middle runners a bit to avoid fouling the mounts.
DJF280 is on the money, The reason to use plate and not build a tubular merger is cost. And either way a tubular merger would push the turbo out at least another 80mm.......into the strut.
I have thought about scalloping the tower to allow more room but I'm not that keen on that idea at the moment.
Posted on: 2013/4/30 18:23
Edited by clyons8 on 2013/4/30 18:39:21
Picture of the underside, curved pan and some very small pieces of flat steel to lead to flange.
jpg  image.jpg (137.12 KB)
7952_518050566e158.jpg 1000X562 px
Posted on: 2013/5/1 0:15
From Brisbane
its more work but moving the flange spot forward you can fit what ever turbo you want.
Posted on: 2013/5/1 2:04
Hey oda, not sure what you mean?
Posted on: 2013/5/1 2:57
Okay you mean get forward away from the tower? I'd be inclined to tilt the flange upward.
This one was made to suit factory inlet manifold, the previous high mount manifold will work with bigger turbos..
Posted on: 2013/5/1 9:35
From WA perth
don,t forget the turbo flange your using only fits certain size turbos not any turbo to what people are saying
Posted on: 2013/5/1 14:17
Manifold finished and fitted with fine thread bolts.
jpg  image.jpg (91.85 KB)
7952_51832b18051c6.jpg 1000X562 px
jpg  image.jpg (96.51 KB)
7952_51832b34474b3.jpg 1000X562 px
Posted on: 2013/5/3 4:13
From Logan, QLD
What size turbo are these to fit? T25 i am guessing?, actually what would be a good size turbo on a a12, with stock cam etc, just one that would boost to about 15 psi on the 1200?.
Posted on: 2013/6/1 8:36
