Browsing this Thread:
1 Anonymous Users
Re: 32/36 Weber DGV jetting |
Registered Users Contentmaster Usermaster
"mild" A15 -- do you mean lower RPM than factory tuning?
Weber 32/36 Baseline for A-series engine is as follows Main Jets: 140/140 Air Correction Jets: 170/160 Idle Jets: 60/50 Emulsion tubes: F50/F50 Jump jet: 50
But you can you use any tuning for a baseline. You note how it works, then modify it depending. The main/air correction is the last thing to check, first check idle mixture range and acceleration transitions.
Posted on: 2013/5/5 1:42
