Re: Tyre Touching Front Shocks While Turning ?
From Bendigo, Victoria
Is it a front wheel drive rim??
Posted on: 2013/5/20 5:46
That is the wrong wheel for a Datsun. It is most likely from a FWD car.
Get a Datsun or Toyota rear-wheel-drive wheel.
Posted on: 2013/5/20 5:55
From Sydney
Looking at the tyre wear, Excessive negative camber will also bring the tyre closer to the strut body, provided the negative was dialed into the strut by bending the the strut body at the base adjacent to the axle spindle.
Posted on: 2013/5/20 6:01
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
True that.
From the photo it can be seen it is not a camber problem. It is the wrong wheel fitted (too much positive offset).
Posted on: 2013/5/20 6:46
« 1 (2)
