I stored a mild Cam in a dry t shirt after lightly oiling it. Was in the boot of stanza for less than 2 weeks.
The boot leaked and the tshirt got wet.
Can got some surface rust on it :x
So I thought,could I wipe with oil and it clean.up?
Some did but the rest was a little more attached.
I thought about scotch BRITE it steel wool.
Figured wet dry 1200 grit with wd40 may be ok.
It cleaned up ok but im worried the light patterns in surface may be pitting.
Would it be safe to use or as a friend told me it may have damaged the hardening so will most likely chew out quicker. Maybe a year it less.
could I use it or should I send it to Cam place for re hardening or grinding?
Or junk it?
There was already wear on the lobes, it was 2nd hand when I got it with a,shaved u67.
Seems a shame to junk it, I posted this on Ozdat too but a lot if learned guys here aren't on there.
