davem69 wrote:
Iam finaly puting together my Early A12 block that has a bit of work done to it iam puting on a recode A14 H89 Head and its has been board out to 75mml with mitsu flat tops pistions.
As all my HEAD BOLTS and PUSH RODS have been mixed up and i would perfer to get new ones.
Is it possiable to get some new ones some where in Brisbane. Or any where ?
Get a quote from Nissan and see what they say but I'm tipping if you live in the same Australia as me, the price will be heavily inflated.
I'm putting together an A12 at the moment with the same head and I've decided to put ARP head studs in. As per usual, they are ridiculously expensive here in Oz and I've been searching offshore for a better price.
I've just found a website called cnc-motorsports who sell the ARP head stud kits for $99.95 plus $14.95 flat rate shipping to here in Oz.
They also sell the Rod bolt kits for $59.95. As I said, check with Nissan first but
you will probably find, it will be cheaper to get these.
Depending on which A12 block you have will determine which of the two head stud kits you need:
Early 1967 - June 1973 - ARP 202-4202
Late June 1973 onwards - ARP 202-4203
If your Engine is an early block it will have the distributor positioned forward closet to the front of the car. Late engines have the distributor located further back in the middle.
Which ARP Head Stud Kit do I needCNC MOTORSPORTS ARP DATSUN
