Re: how to test alternator??
Yes, best way is to test with Voltmeter (borrow one if necessary). Put a load on the running engine (turn on headlights). If the voltage drops below, you have a problem with the alternator.
So the charging light flashes when you put on the turn-signal indicators? Sounds like it might be a wiring problem, maybe the ground wire for the dash-gauge assembly is loose.
Posted on: 2004/5/6 16:05
Subject Poster Date
     how to test alternator?? nicholas 2004/5/6 9:30
       Re: how to test alternator?? dattodevil 2004/5/6 11:30
         Re: how to test alternator?? ddgonzal 2004/5/6 16:05
           Re: how to test alternator?? go_the_datto 2004/5/7 5:50
             Re: how to test alternator?? enos1 2004/5/7 19:42
               Re: how to test alternator?? dattodevil 2004/5/8 0:10
                 Re: how to test alternator?? phunkdoktaspok 2004/5/8 2:03
                   Re: how to test alternator?? ddgonzal 2004/5/8 5:30
