(1) 2 3 4 »
engine problem
Quite a regular
hi all,i have a problem with my a12 engine it hard to start when it does start it will not idel I tried a new dizzy cap points are not very old. the new carburettor has been on for 2 months, when I do get it running its runs rough. has got any ideas will much appreciated thanks
Posted on: 2013/6/22 6:47
Re: engine problem
When did the problem start happening? That will help narrow down the likely cause.
A new carburetor will not idle correctly until it has been tuned. Set the idle speed screw then the idle mixture screw.
Posted on: 2013/6/22 7:04
Re: engine problem
Quite a regular
it started when I put some petrol in ,but I put petrol in my other car as well nothing happen to that car
Posted on: 2013/6/22 10:01
Re: engine problem
For idling problems that start with a tank of petrol, I would rinse out the fuel bowl.
Posted on: 2013/6/22 19:51
Re: engine problem
Quite a regular
hi I got some carburettor spray cleaner and got it idleing just but back firing in carburettor and running rough any ideas
Posted on: 2013/6/23 4:50
Re: engine problem
From Kelmscott Western Australia
Know its stupid but there could be Vaccum leak ?
Posted on: 2013/6/23 5:01
71 Datsun 1200 ute with A14 fuel injection and T50
59 Morris minor ute with A15 fuel injected with intercooled turbo
Re: engine problem
From stinking hot cairns
rev it up with the filter cover off and put your hand over the carb inlet, it will want to stall then take your hand off letting the revs increase.do this a few times and if your lucky it will pull the #OOPS# out off your jets. you most likely got a tank full of water.
Posted on: 2013/6/23 5:33
Re: engine problem
Quite a regular
hi there was leak but was fix, I don't know much about the carb if you take off the air filter and looking down the carb only one jet putting fuel in but the other one nothing is that normal???
Posted on: 2013/6/23 10:02
Re: engine problem
That is normal.
Posted on: 2013/6/23 18:03
Re: engine problem
Quite a regular
clean out carb sounds better but still back firing through carburettor. the manifold thermostat the shaft is very worn would that cause the back firing
Posted on: 2013/6/24 7:09
(1) 2 3 4 »
