Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#11
Re: engine problem
datsunbeginner
Posted on: 2013/6/24 7:14
Have you checked that the fuel pump is adequately providing fuel to the carbie?
#12
Re: engine problem
old-tin
Posted on: 2013/6/24 7:38
did you just clean the bowl? or the jets, emulation tubes and obviously the rest of the idle circuit? also if it happened after you filed up you would think there is probably more #OOPS# in the tank.
#13
Re: engine problem
nustad12
Posted on: 2013/6/24 9:15
hi all, I took off the carb took out the secondary main jet and primary jet and blew compressed air through out no sign of water in fuel I took hose off held a container in front of hose plenty of petrol came through after all that, its idles better and when I rev it up it back fires through carb
#14
Re: engine problem
zordmaker
Posted on: 2013/6/24 11:53
I just had a prob like that and it turned out to be a fouled plug. Idled fine but misfired on acceleration. Cleaned and reset plugs ad all fine
ZM
#15
Re: engine problem
nustad12
Posted on: 2013/6/25 4:46
checked all plug gaps and cleaned and checked points and timing that stop that stopped the back firing, now when it idles its up and down and blows blue smoke, I try to adjust carb to lean still change
#16
Re: engine problem
Posted on: 2013/6/25 4:55
Congrats on solving the backfiring problem.
Blowing blue smoke ... ensure the oil level is not overfull. Otherwise most likely the engine needs an overhaul.
#17
Re: engine problem
nustad12
Posted on: 2013/6/25 5:54
thanks, the engine been done the end of 2012 its done very little k,s
#18
Re: engine problem
benny
Posted on: 2013/6/25 6:49
Rings may not have bedded in correctly since the rebuild leading to excessive oil on the bores resulting in burning and blue smoke.
#19
Re: engine problem
nustad12
Posted on: 2013/6/26 7:29
when idling very little but when I rev it up it blows a lot more blue smoke would it possible be only valve stems seals??
#20
Re: engine problem
Posted on: 2013/6/26 9:11
Valve stem seals usualy at idle or on take off. Rings usually at revs as far as I know
