« 1 (2)
Re: Temperature.
From Trinidad and tobago
i see your point there i will have a check on that.Water pump is ok so since your fan is on similar position to mines what direction does yours work pulling air away from rad or pushing towards it?
Posted on: 2013/7/4 16:00
'71 Four Door Sedan.
Street Sleeper!
STILL LIVIN' THE 70'S LIFE !!
Re: Temperature.
Fan on front needs to push air through the radiator into engine bay.
You need to make sure not only fan is spinning the right way but the profile of yhe blare is the right way too.
Get a piece of paper and turn fan on.
The see from front if it tries to push air away from rad or through it.
Also then test engine bay side for the same.
Posted on: 2013/7/4 22:51
Re: Temperature.
Ok
Replaced a Faulty Radiator cap today an the fan was spinning the wrong way It was pulling air towards the front of the car so i switched around the wires now its pushing towards the rad, i will have to drive the car because i had the car idling for a while and the electric fan did not even come on yet,it was getting late so next time i will see how it all goes!
Posted on: 2013/7/5 1:53
Street Sleeper!
Re: Temperature.
hey darren
mine sucks air from outside the front grill and directs/pushes it towards radiator/engine side.So your fan is now spinning the right way.Funny how some people wonder where the fan is as it can't be seen behind grill.lol.
if you have a good quality fan, id get rid of the mechanical fan.
make sure u run a fuse for the fan too.
heres some pics of my setup.the holden sealer is for the bolts holding the fan to radiator.most of the things can be found at hardware stores.
also with your mechanical fan running, i wonder if the temp will be high enough to activate the fan switch.on what temp is ur switch activated?
jpg  20130617_173521.jpg (73.53 KB)
15239_51d696fc3d851.jpg 800X600 px
jpg  20130617_135455.jpg (56.32 KB)
15239_51d6977696d5e.jpg 800X600 px
jpg  20130618_095741.jpg (57.21 KB)
15239_51d69868e6761.jpg 800X600 px
jpg  20130618_094800.jpg (90.60 KB)
15239_51d69899be60f.jpg 800X600 px
jpg  20130619_084840.jpg (82.14 KB)
15239_51d698b2d08e9.jpg 800X600 px
jpg  20130705_184735.jpg (72.84 KB)
15239_51d698cb5a76e.jpg 800X600 px
jpg  20130618_100741.jpg (68.76 KB)
15239_51d698feb5e7c.jpg 800X600 px
jpg  20130618_100702.jpg (64.70 KB)
15239_51d69910e4d44.jpg 800X600 px
jpg  20130617_180229.jpg (49.91 KB)
15239_51d699343fa11.jpg 800X600 px
jpg  20130619_081629.jpg (121.05 KB)
15239_51d69a11b359c.jpg 800X600 px
jpg  20130629_124334.jpg (87.76 KB)
15239_51d69b8125642.jpg 800X600 px
jpg  20130629_124356.jpg (51.88 KB)
15239_51d69b9163464.jpg 800X600 px
jpg  20130629_124412.jpg (95.86 KB)
15239_51d69ba50d98d.jpg 800X600 px
jpg  20130629_124429.jpg (180.87 KB)
15239_51d69bb450ce1.jpg 800X600 px
Posted on: 2013/7/5 11:13
Re: Temperature.
Love the air cleaner.
Instead of bolts through the rad you could mount the fan directly to the car. No rad issues then
Posted on: 2013/7/5 12:56
Re: Temperature.
Thanks alot A12grunt your pics help me out nicely showing step by step apriciate it should add it to the wiki
The main problem my a15 had the temperature pasting 1/4 from colt start in about 4 mins
Problem tured out to be a faulty rad cap!
A pic of the wiring of thurmo and fan.
Plus heres a pic of how far the temperature reached a 1 time.
Posted on: 2013/7/7 6:08
Street Sleeper!
« 1 (2)
