Re: BeeJJ 2 Door 1200 Sedan, Turbo?
From Western Australia
cheers shaun, yea looked through your build, very nice work!
yea all the floors have rust, but just in sections so they can be patched relatively easily. Going to put new sills on too as they arent the best.
Couple of spots around wheel arches and the rear window lip needs attention.
Plenty to do but not the worst rust on a datto I have seen...
Posted on: 2013/7/14 11:51
1974 1200 Ute - Build
From mandurah
DD there is 12 1200s that I know of south of the river ! But thats just guys ive dealt with or spoken too
Nice work brett ! Top work cant wait to see it finished! , nige is pretty awesome with rust work , top bloke too
Wish my 1200 had rust so nige would come see me again hahaha!
Posted on: 2013/7/14 18:20
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
Ok little bit more progress with the 2dr.
I ordered a window removal kit off ebay for $20. Actually worked pretty well. Taking my time I managed to remove the rear window without damage. The seal was totally stuffed. Rock hard and cracked everywhere so that made it a lot harder.
here is the end result:
With the window removed I could inspect the parcel shelf corners closer. As the seal was buggered for along time and the car was left outside there is rust in both corners:
Then I started wire-wheeling the boot floor and cutting out the rusted metal:
Posted on: 2013/7/17 10:32
Strip and sandblast?
Posted on: 2013/7/17 11:41
Thought about it Chris but super $$ here and I think I can strip it myself.
I have a diy sandblast kit here for certain areas
Posted on: 2013/7/17 12:44
more rust repairs 2day with Nige!
Bad spots cut out, KBS rust seal inside the rails of frame then weld through primer on all other areas where welding occurs..
2nd step result on other side, new metal is but welded in, then cleaned and prep'd with KBS products. KBS rust sealed and the KBS numetal epoxy putty used around but welds to fill any minor gaps or imperfections... This will then be sanded and more KBS applied on the top
rear window was heavily stripped back and soaked in KBS rust blast for many hours, then KBS rust sealed
new metal tacked in..
Posted on: 2013/7/27 9:50
From penrith,sydney,aus
Nice work mate, where did you get the replacement bit, mine is also rusted pretty bad in this area
Posted on: 2013/7/27 11:28
2 door 1200 sedan project l20b stroker
From Gold Coast
Good start, can't wait to see it finished
Posted on: 2013/7/27 11:43
Cheers turboute
Shaun
All the replacements so far are just from sheet metal other than the rear lip which was from a donor sedan
Posted on: 2013/7/27 12:39
From Perth WA AUS
Getting there, can't wait to get back into it!
Posted on: 2013/8/2 9:09
Datsun 1200 2Dr sedan.
« 1 2 (3) 4 5 »
