Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#21
Re: Temp sensor removal.
HakotoraGB-R
Posted on: 2013/8/9 23:01
Yep youve got it, the sender is basicly just a hollow brass (or copper?) tube with a capped end and a couple wires inside with a nut sweated onto the outside. When i tried to remove it the nut came away from the tube and screwed out leaving the empty tube stuck in the head. Will load some pics soon,
cheers joel
#22
Posted on: 2013/8/10 2:50
#23
b310gx
Posted on: 2013/8/10 3:18
You can get to the bottom of the sender through the thermostat hole. Use a drift to try & push the sender out the top. Another way is instead of an ezy-out,use a large tap into the sender for a few turns, this should break the bond between the brass sender & the aluminium head & it should pull out. If none of these work, try cutting down the inside of the sender with a sharp chisel & fold the sides in on itself & it should come out. I've never had the last fail (yet) so I haven't had to figure anything else yet. Just be careful with the thread when using the chisel.
#24
HakotoraGB-R
Posted on: 2013/8/10 8:51
Nice one b310gx, some very good ideas there, cheers very much.
