Browsing this Thread:
leaf springs
From sydney
i heard somewhere that if i were to remove the stock springs in my ute and replace them with sedan leaf springs , i would get a better ride? does anyone know if this is true??
Posted on: 2013/8/9 11:36
Re: leaf springs
Quite a regular
From Mid North Coast N.S.W
I wouldn't be able to say for sure but the ute springs imo would be stiffer than the sedan springs. Therefore if your willing to sacrifice load-carrying ability for drive-ability then the softer spring should handle a bit better.
Posted on: 2013/8/9 11:49
'72' B110 sdn
'68' (allegedly) B110 sdn
'72' 808 sdn
'00' E50 ELGRAND
'93' JZA80 Supra
Re: leaf springs
From Ballarat Victoria
I do a leaf spring treatment that greatly improves ride and traction.
The leaves are separated, media blasted then treated with Graphite, Molybdenum disulphide, and PTFE. This greatly reduces friction between the leaves, improving ride and handling.
It costs $150. to get them done tho.
Let me know if you are interested.
Cheers,
Simon
Posted on: 2013/8/10 0:45
VIC DYNO HIRE
Re: leaf springs
From Melbourne, Australia
Definately better off in the ute with the sedan/coupe springs or at least removing the additional load spring
ute springs are designed for 500kG pay load so are way too stiff without a load in the tray
check the wiki for the exact spring rate diffferences
that sounds very interesting sikyne, probably worth it
Posted on: 2013/8/10 2:35
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: leaf springs
From sydney
thanks, the most i would carry is 100kg roughly , that sounds like a good idea sikyne , i already have a set of sedan springs though, thanks heaps
Posted on: 2013/8/10 11:44
