Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
60A 5 Speed fitting to 120y
cossee
Posted on: 2013/8/15 22:14
Hi All. Just scored a 60A Series 5 Speeder and going to fit to my 1975 120y 4Dr, Anyone have advise fitting one,? On the cross member and driveshaft I Was told you can get an aftermarket Gearbox Mount/ cross member to fit without any Mod's required ? Also anyone know if STD 120y Driveshaft ok to use or needs any Mods., ? Also anyone heard of the Gearbox Short shift Kit to suit the 60A ? Cheers all, Steve cossee@xtra.co.nz
#3
Re: 60A 5 Speed fitting to 120y
cossee
Posted on: 2013/8/16 0:51
Hi Cheers for that, Do you know if there still operating in OZ ? Can only get to their Asian site, Cheers
#4
Posted on: 2013/8/16 1:59
60-series 5-speed uses same driveshaft as 56 or 60 series 4-speed.
The gearbox crossmember is a stock B210 piece, but differs from the 56-series crossmember. You can use the existing 1200/120Y crossmember and a simple adapter. See http://datsun1200.com/modules/mediawi ... on#Using_1200_Crossmember
#5
cossee
Posted on: 2013/8/16 18:03
Hi All. Many thanks for the info from Forum, Was a real help.
NOW: DOES ANYONE HAVE a Clutch Fork and Bearing for the 60A 5 Speeder Gearbox came without it ##### If anyone does, PLEASE Email me at cossee@xtra.co.nz I live in Paparoa, Northland 0543. So if have one send price including Freight. Also the Cross member, Checked with BJ Projects and whoa expensive, If any one has one, Either Genuine BJ Projects or one made up to fit I'm interested. If not have to bite bullet and get one from BJ Projects. NEED HELP. Cheers Steve
#6
Posted on: 2013/8/17 2:46
#7
cossee
Posted on: 2013/8/29 17:34
Finally Got the 60A box and a new Cross member from BJPprojects. Ask now,I've Been told to use Only a Special Grade and Brand of Oil in the 60A ? This correct ? Thanks to members. Cheers Steve. cossee@xtra.co.nz
#8
Posted on: 2013/8/30 1:12
Not correct. The modern recommendation is still the same one in the 1971 Datsun 1200 owner's manual: API GL-4
Quote: Nissan recommendation Modern formulations fully synthetic or partially synthetic mixes. However, many boxes are 30 years old still with good synchros having used regular non-synthetic oil. Keep it full, keep it fresh is the important thing. See http://datsun1200.com/modules/mediawi ... ssion_Overview#Lubricants
#9
Posted on: 2013/8/30 1:36
