« 1 (2) 3 »
Re: Thaughts on running no brake booster?
From Melbourne, Australia
Bigger master just means you have to use more force but push the pedal less distance
A small master means you can use less force (and therefore not need a booster) but the pedal will travel further. As long as you do not run out of travel on the small master then that is fine. This is the way i like my brake pedal
my brother put a 7/8th master in an escort (in anticipation of a big brake upgrade he never got around to doing), the pedal would not move more than 10mm and you had to brace yourself against the seat to be able to press it hard enough
the theory if you can be bothered reading it
Posted on: 2013/8/21 3:34
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Narellan,Sydney
So in saying that 1200rallycar would you think I should go for a little smaller master then the 7/8" Evan with my bigger brakes? Or would it have been better on your brothers legs to go the bigger brakes?
Posted on: 2013/8/21 9:13
All stainless steel-mild steel Sheetmetal and tube work
All types of welding
Custom metal polishing
BSA custom fabrication 0415 904 474
From Sydney
heys guys just seen this post and thought id ask a quick question, how do you remove althe boosters and is there any mods you need to do for brakes?
Posted on: 2013/8/21 9:40
From windsor, sydney
Sorry datrotor but you started to loose me when you said good quality and willwood in the same sentence , but that said willwood does actually have a relevant formula on their web site that can give master cyl size calculations . But you need a lot of info to fill in the formula , you will need to know front Caliper total piston area , same for rear , pedal ratio and desired pedal effort in newtons , while previous experience can give you a starting point some track testing is sometimes the only way to tune in the correct size
Posted on: 2013/8/21 10:53
WARDMAN ENGINEERING
CNC machining
Race Car Fabrication
Suspension, Brake, Drivetrain modification
TIG welding of all metals
0413 595 627
Wards I was under the impression wilwood is good which is why most race/drag cars use them?
Posted on: 2013/8/21 11:26
From Perth
They use them because they are cheap
The Datsun master can be had in many bore sizes
So start with the basics if you already have one and work up or down depending what your leg likes
My 1000 conversions I have used 11/16 , 3/4 and 13/16 on my cars
And one customer even used 7/8 for his
So you can tailor it to suit your needs
All suitably modified for disc brakes of course
And as far as working out forumulas... they don't take into account hose flex , pad compressability , flex in the caliper bodies , movement on the slide pins and a number of other factors... so can only be used as a guide
Posted on: 2013/8/21 11:39
If every1 dosnt like wilwood what's a good brand?
Posted on: 2013/8/21 11:57
you get what you pay for, if you cant find a OEM part that suits your needs , AP racing or Brembo are hard to beat , but they are not cheap
Posted on: 2013/8/21 12:10
WARDMAN ENGINEERING
CNC machining
0413 595 627
A good brand is Nissan -- Nissan make awesome 4-pot alloy calipers.
Nissan 4-spot brakes on 1200 strut
Posted on: 2013/8/21 22:16
What have Nissan calipers got to do with a booster or not?
Posted on: 2013/8/22 3:43
« 1 (2) 3 »
