#21 Re: Silvia brakes on 1200 struts
benny Posted on: 2013/8/20 9:26
Here is couple of pics of the conversion [250mm rotors] from several years back.
#22 Re: Silvia brakes on 1200 struts
Boss1200Ute Posted on: 2013/8/21 11:24
Hey Benny what struts are they? I was thinking about using my standard 1200 ute struts with this break conversion and coilover sleeves but if the 120Y struts are the better way to go about things then I'll make the swap. How much difference in offset is the between the standard strut and 120's because Im sitting pretty flush at the moment with my wheels?
#23 Re: Silvia brakes on 1200 struts
ddgonzal Posted on: 2013/8/21 22:11
120Y struts are same as 1200 disc-brake struts. The biggest difference is which hubs you use. You can fit disc-brake hubs or drum-brake hubs on a disc-brake strut. The drum-brake hubs need no machining for 250mm Silvia rotors.
« 1 2 (3)
