Re: water in crankcase - LOTS OF WATER
thumb in hole........
Watch out unfamilia will pop up........... Pop up and pop in. Greek style.
Posted on: 2013/9/18 7:16
Nothings poped up yet chris.... give me a handy
Posted on: 2013/9/18 7:39
I agree with Townie, Check that there wasnt a water hose conected to the engine breather. It's the steel pipe that comes out on L/H side (manifold side) of the block towards the rear.
Posted on: 2013/9/18 8:16
yep.... stupid, stupid, stupid!
Problem solved!!!!
hooked up the rear hoses wrong.
It appears that one of the rear hoses that go into the block is a breather not a coolant hose.
thank you for all the help
Posted on: 2013/9/18 17:11
From Logan, QLD
Good to see a result, I wonder if the motor will be ok, got alot of cleaning to do!.
Posted on: 2013/9/18 21:11
From Canberra
I did this myself with my first Datsun 1200 and cleaned it up and it worked fine just ALOT OF CLEANING and drying... but never had an issue once it was cleaned
Posted on: 2013/9/19 7:57
From sydney.nsw
yes ,loosekid, i remember that one well,
hows the engine going now.
cheers
Posted on: 2013/9/19 22:28
A.T.E RACE ENGINES: ( " AUST 1 " 2010 ) A15 GO THE DATTOS... 0412 864 741
« 1 (2)
