Re: Wheel Alignment Report
Look at my Wheel Alignment Report do you see any issue there ?
Wheel Aliignment_new.jpg (43.97 KB)
Yes, I see a problem:
Camber (front left): -0.80
Camber (front right): +3.20
That's a huge difference left-to-right.
Posted on: 2013/9/24 4:27
From Sri Lanka
Hi DD
thanks. i talked to the particular technician who did this, he said will balance the tires and re fix them.
and also major issue here in the alignment they select a manufacturer (nissan) and particular year (In this it says N14 sunny -1994-1995) in the machine it does according to the car manufacturer.
thanks
regards
sumith
jpg  Bill Header.jpg (37.56 KB)
10994_524114c666151.jpg 640X480 px
Posted on: 2013/9/24 5:28
From Sri Lanka
Hi DD
According to the Wiki 1200 Camber in non Adjustable is it ? This is 1978 Hb310
http://datsun1200.com/modules/mediawiki/index.php?title=Camber
will i be abbe to adjust my camber problem ? if not what parts should be replaced to make the proper camber ?
thanks
regards
sumith
Posted on: 2013/9/25 4:28
Edited by Sumith on 2013/9/25 4:44:23
Re: New Tie Rod Ends
Yes, camber is non-adjustable when using the factory parts. But your camber is out-of-spec (greater than the maximum). Nissan recommends finding out which part is bent and replacing it.
The camber is most likely not the cause of the shaking.
Posted on: 2013/9/25 4:51
From Sri Lanka
hi Guys
I went to the alignment place and they found the issue on the Cross ROD bar ends they have a free play on them, Are those replaceable or repairable or do i need to find a good one ? Damn do i have to push the all set back down to repair it ?
thanks
regards
sumith
jpg  Resized Cross ROD.jpg (53.68 KB)
10994_5243d8f916242.jpg 480X640 px
Posted on: 2013/9/26 7:49
A professional alignment is supposed to include inspection for such problems in the first place.
I have not heard if they are repairable. Only replaceable.
Posted on: 2013/9/26 17:13
« 1 (2)
