Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#11
Re: 20b rotary
sikdatto1200
Posted on: 2004/5/13 8:23
yea would be awsome with that much power in a little twelve hundred. mite need to mini tub it tho or you would never get anywere, too much tyre frying
#12
Re: 20b rotary
thebuzz
Posted on: 2004/5/13 12:21
Yes traction would be quite an issue!
I have a 13B in mine, with a GT35/40 roller bearing turbo, it currently makes around 220kws at the wheels (no intercooler, water injection is used instead) and as you would imagine, the 175s on it don't grip for too long once it comes on boost ![]() One thing you can't beat however is the sound of an angry 20B, they are awesome!!! Here are some more pics of my car... http://mazdarotary.alphalink.com.au/datsun/
#13
Re: 20b rotary
thebuzz
Posted on: 2004/5/13 12:34
Also if anyone is interested in hearing/seeing some 20B powered cars in action, check out the 'Videos' page on www.mazdarotary.net where there are a few videos available to download of 20B-powered cars.
#14
Re: 20b rotary
jaimecidpedro
Posted on: 2004/5/18 1:37
Nice job, nice looking rotary 1200 Datto. Just watch out , that motor, that weight, on those tires......
make sure no beer is around...you might forget about the tires, and ...please, add some substance to that car, it is excelent, aside from the tires, it is a safety issue, not just looks.Cheers. ______________________
#15
Re: 20b rotary
Drifft
Posted on: 2004/5/18 7:04
13BT's make either 138kw or 153kw @ 6500rpm standard if you go for either the series IV or series V type which seems to be most peoples choice. a standard 20BT makes 208kw @6500. if your not worried about the price i think going for a 20b would be awesome aswell as probly smarted becasue the way i see it is you can either have a worked 13b making 200kw or you can have a standard 20b making 200kw, the 20b being standard making it way more reliable not to mention nice rough 20b sound that cant be mistaken for anything but a 20b. also the 20b has almost double the torque of a standard 13b so for these reasons i think the 20b would be a great choice however like was mentioned before you have no chance in hell of getting it road registered. with strengthening it up you would want to do this which ever way you go so thats not really an issue. my make has a ca in his 1600 (makes 215rwkw) and this played havoc with the body of it so obviously it would be in your best intrest to seam weld it at least but yeah if your not worried about not being able to road register it or about the coast i recon go with it and good luck
#16
Re: 20b rotary
thebuzz
Posted on: 2004/5/18 7:27
An engine conversion involves a lot more than just putting a standard motor in, take for example the 'standard' Stage 1 13BT conversion available from RotorWorx which can be found here: http://rotorworx.com.au/engine_packages.html
Power is quoted at 180kw at the wheels, which would be somewhere around 230+ at the engine, which a lot more than the standard S4/5 13BT made from factory, and this still retains the standard turbo. This conversion costs around $7500 A 20B engine alone will be at least $4000 if you can find one You can view topic.
