#1 aftermarket sway bar link assembly too tall?
datsunbeginner Posted on: 2013/10/21 0:41
I bought a set of these off eBay
I was told they would fit a 1200 but they seem about an 1" taller than the stock sway bar links. I don't think this will work well as it might change the geometry of the sway bar?
Anyone run into this issue as well?
#2 Re: aftermarket sway bar link assembly too tall?
datsunbeginner Posted on: 2013/10/21 0:43
Pic
jpg  $(KGrHqIOKjwE3QmcNN5QBN8H+iMjog~~_35.jpg (9.31 KB)
13419_52646a95bb8b5.jpg 300X299 px
#3 Re: aftermarket sway bar link assembly too tall?
L18_B110 Posted on: 2013/10/21 2:09
easily fixed - cut down the sleeve to suit, and use a shorter bolt if neccesary.
#4 Re: aftermarket sway bar link assembly too tall?
datsunbeginner Posted on: 2013/10/21 2:14
I think the discrepancy is in the sleeve. I think you are right though Harry. If I cut down the sleeve to match the standard height it should be okay. Good thinking.
#5 Re: aftermarket sway bar link assembly too tall?
supafatto Posted on: 2013/10/21 9:37
Yeah I did the same thing years back I cut the sleeve and was good
#6 Re: aftermarket sway bar link assembly too tall?
datsunbeginner Posted on: 2013/10/22 2:42
After further examination it is not the sleeve.
It appears the bushings are too big? Am I being too paranoid?
jpg  bushings2.jpg (128.71 KB)
13419_5265d8107245f.jpg 648X486 px
#7 Re: aftermarket sway bar link assembly too tall?
datsunbeginner Posted on: 2013/10/22 2:43
Next question - Which way is up on the sway bar?
#8 Re: aftermarket sway bar link assembly too tall?
datsunbeginner Posted on: 2013/10/24 2:07
sway bar bushings. make sure the bar is tight in the brackets. Replace the bushings as necessary. Also, make sure the side of the bar with factory white paint mark is installed on the left side of the vehicle
Oops. I painted my sway bar and don't know which way to put it now?
#9 Re: aftermarket sway bar link assembly too tall?
L18_B110 Posted on: 2013/10/24 2:22
the dip in the center goes down - if that makes sense...
#10 Re: aftermarket sway bar link assembly too tall?
datsunbeginner Posted on: 2013/10/24 3:53
I think I know what you mean but not 100% sure. Whats your opinion on the new link bars, yay or nay? I could just use the bushings on the stock link bar too?
