#21 Re: TWIN CAM A15
DATO_FREAK Posted on: 2013/10/21 18:31
um, excuse me if its just me not seeing it through the pics provided but that block doesn't look like an A Series block.
Look at where the alternator is bolted straight to the block, A series doesn't do that - either side. The oil pump and filer is normaly there.
Water outlet on front comes out from head, not block and there is an outlet on the front passenger(lhs) of car.
Am i wrong, or just not seeing it right?
#22 Re: TWIN CAM A15
LittleFireyOne Posted on: 2013/10/21 21:54
There could be some simple explanations for that. Take the water inlet, the timing case appears to be removed and the inlet goes straight down around there the pump was while blocking the sideentry point. I can't really explain the alternator unless a bracket has been flipped
#23 Re: TWIN CAM A15
D Posted on: 2013/10/22 3:05
Alternator has NO issue & never would be one!, its using original mount and it would never be a problem its the easiest part of any conversion LOL!.
The guy is ingenious, took something cheap home and went from there and beat every japanese tinkerer of the A series from his backyard. Yet still remaining A series heart seems he wanted to be different, took the challenge stuck it to the haters and did it his way.
Sealed timing case area and pushrod cavities from oil, sorted water flow issues electric water pump similar front water outlet like on a late suzuki M series block or older Fiat Twin cam, 78 or 79mm mazda bores/slugs, crank snout sorted for belt cog and crank pulley, belt cog mounted instead of timing sprocket on cam and it keeps going.
Lemonheads big block had 82mm sleeved with room for 83.5 mm for future rebuilds
so 1800cc wouldnt be a bad way to go with the turbo bits from BPT in the 323 GTX or Ford laser TX3. The Mx5 guys are getting over 320hp with boosted b6.
http://7kyo.wordpress.com/2013/08/23/ ... ed-into-a-miata-bp-motor/
Kia also uses these engines! just in case peeps cant find a head from Mazda
The rest is just ingenious and the options of the A series have taken a big boost!
#24 Re: TWIN CAM A15
LittleFireyOne Posted on: 2013/10/22 10:23
Kia? surely not? what model?
#25 Re: TWIN CAM A15
Curtis Posted on: 2013/10/22 10:40
sooooo would it still be classified as a a-series engine for rego purpose's??
#26 Re: TWIN CAM A15
LittleFireyOne Posted on: 2013/10/22 11:47
yep, engine is based on the block.
#27 Re: TWIN CAM A15
D Posted on: 2013/10/22 13:20
Ive mainly seen the F series mazda engine in Kias but maybe overlooked the B series as they look almost the same on the rocker cover. Wikipedia should have the info on which models to look out for here.
At the bottom front of the block where the crank pulley meets the sump there is some finicky stuff that needs to happen and water outlet could be piped from the head instead as in this pic shows how the rwd miata/mx5 use the provision which is already there for the rwd or fwd layouts to reduce tooling and casting new heads.
jpg  mazda BP water inlet on head.jpg (60.96 KB)
737_52666eb168963.jpg 500X438 px
jpg  mazda BP water inlet on head 3.jpg (75.83 KB)
737_526683037f7dd.jpg 800X531 px
#28 Re: TWIN CAM A15
D Posted on: 2013/10/22 14:55
The first pic in black is using the 323 rocker cover as they interchange and RWD with front of the head water inlet while the last 1 in white is a FWD BP in a RWD chassis (notice the water outlet on the opposite side as the one in the datsun on this thread and front of head sealed up like on all fwd applications) also notice it doesnt look too bad with quads and white rocker cover:))
jpg  mazda BP.jpg (90.24 KB)
737_5266861935b6c.jpg 538X363 px
jpg  fwd in rwd.jpg (199.71 KB)
737_52668625369d5.jpg 1287X991 px
#29 Re: TWIN CAM A15
D Posted on: 2013/10/22 15:34
The Z series head which is a modern narrow valve, high port design also available with VVT for the b series. The VE version is for a 1500cc model that produces 96 kws thats 100cc less than the 85 and 100kw 4age.
The Z head is compatible is everyway to the B series block.
There is also the last of the wide angle B series donks with
VVT, solid lifters like the Z head and 1800cc making 163hp.
Same head used for the Australian Bathurst MX5 SP Turbo.
That been said it seems to be also possible to use the smaller diameter Z series pulleys and crank cog which will reduce/improve front cover sizing on the B series.
jpg  cam gears difference.jpg (62.60 KB)
737_52668d34a61d3.jpg 448X336 px
jpg  crank gear difference zm vs b6.jpg (69.25 KB)
737_52668d6078c74.jpg 448X336 px
jpg  zm head on b6 block.jpg (83.02 KB)
737_52668d7531b04.jpg 448X336 px
#30 Re: TWIN CAM A15
D Posted on: 2013/10/22 16:00
You wanna go quads I hear and for the price of a weber manifold for the A series you can go billet manifold for this head! to take 4age 20v quad itbs
https://technotoytuning.com/mazda/na18 ... 4ag-throttles-18l-na-head
jpg  tbi.jpg (43.79 KB)
737_52669300b4e23.jpg 940X360 px
« 1 2 (3) 4 »
