Re: TWIN CAM A15
funny enough had to check my dungeon for some parts and ironically I had a Z5 head a while back when test fitting a possible twin cam for the A series as the heads where $20 at pick a part one week and also bought a Daihatsu 16v head but never got around to playing with them.
The Mazda Z head has the same bolt up pattern totally compatible with the B series and here are some happy snaps of the Z5 front camshaft lobe cap that separates the oil from the belt drive area at the front. Just a comparison on how narrow and compact these heads are.
Anyone know if they ever made a side style dizzie cap for the A series? the last pics shows a Morris Lucas one with Pertronix kit
Here is a build thread of the Z head on a B series block
http://www.miataturbo.net/build-threa ... zm-de-engine-build-62722/
jpg  A series head vs Z Mazda bits.jpg (168.56 KB)
737_5267c2f6d400f.jpg 800X578 px
jpg  L series vs Mazda Z.jpg (146.65 KB)
737_5267c300929ba.jpg 900X506 px
jpg  side dissie2.jpg (22.11 KB)
737_5267d15be9ae0.jpg 349X256 px
Posted on: 2013/10/23 13:40
Edited by D on 2013/10/23 14:38:12
Edited by D on 2013/10/23 14:38:38
Re: TWIN CAM A15
From Las Vegas USA
Cool stuff but I still would love to know more about the nuts and bolts of the conversion. If we could buy some of the fabricated components that would be really cool.
Tom
Posted on: 2013/10/25 2:36
Re: TWIN CAM A15
If we can help each other like the Ozdat guys input on the L series Ka24de head we would all be not far from buzzing around with Mx5/Miata/323 GTX/Ford Tx3 power in much lighter bodies than the original bodies these heads came in.
So far I can see the timing case area has a cover which must lead to a shortened sump, the cover must have a thin seal to avoid leads from the crank snout which also takes the belt cog to suit the head cambelt cogs, some tensioner pulleys to hold the belt in place, a 3rd camshaft pulley to run the oil pump and dizzie if we like.
The water inlet could be at the front off the head where the provision is easier than straight to the front of the block and side outlet could be used on the block using one of the welsh plugs so water goes into the head first from the front, holes on the gasket towards the rear so water flows across the head then onto the rear of the block and to the front again out the side of the exhaust side front welsh plug. This would make easier setup using a Johnson style mechanical external water pump or custom made external water pump using a common off the shelve waterpump that is relatively square like a suzuki M13a or M series water pump housed in a dome alloy case with in and out pipes.
Carbs could be run using a shorter version distributor with side exit spark plug dissie cap like last pic on my last post.
Bore would need to be like original B or Z series at 78mm or over, belt would have to be custom as it seems longer so will need to be sorted from gates or other belt manufacturer unless the ingenious pioneer of this conversion lets us in a bit more.
Would be nice to invest in some ARP head studs for this conversion and start recasting some of the twin weber manifolds which where avail from japan, south africa and USA.
Also eventually once quite a few are committed to the build we can get a custom made alloy, steel or hybrid alloy/clear plastic belt cover to suit our tastes.
Headers are one of the things which are easily avail for this head amongst a zillion of miata aftermarket goodies.
Some of the Miata forums are taking their BP engines to 173bhp at the wheels normally aspirated so we would need to rev our engines a bit higher for the lack of 200cc or sleeve our A14/15 blocks to 83mm for 1775cc or get someone to prep a handful of E16 cranks along with 83mm bores for 1905cc :))
The other thing is the oil feed, drain and brazing/brass pluging up the pushrod cavities and maybe some of the water galleries need modifying.
Custom head gaskets are avaialable for 100 one off using very good materials and cheaper in quantity once the pattern is sorted but I can see the mazda head has equal bore spacing meaning offset boring is possible or offset sleeving for that extra capacity we hunger for.
Pics below illustrate the areas of interest, look at the oil feed areas!
disregard the head gasket on the head its a b6 hg on the Z head to show
how compatible the Z heads are the B series block.
jpg  zm head gass.jpg (77.04 KB)
737_5269e8db2f381.jpg 448X336 px
jpg  a15 block with 76mm bores.jpg (105.54 KB)
737_5269eaf2d8718.jpg 940X586 px
Posted on: 2013/10/25 4:35
Edited by D on 2013/10/25 4:58:55
Edited by D on 2013/10/25 5:02:30
Re: TWIN CAM A15
Posted on: 2013/10/30 14:35
« 1 2 3 (4)
