« 1 (2)
Re: Why change from stock 1200 struts?
From Las Vegas USA
One note on the 1200 struts, the 240Z springs will fit on the 1200 strut so that's an easy way to get stiffer springs. For the street I would also be OK with the 1200 wheel bearings.
Tom
Posted on: 2013/10/25 2:42
Yes, 240Z rear springs fit, but are fairly soft.
Posted on: 2013/10/25 4:32
From Geelong, Victoria
demacoz wrote:
Before having a detailed discussion about the struts have you had a detailed discussion about the turbo?
Demacoz, I have discussed the conversion with my engineer, I am trying to get all the info together for our meeting which will include front / rear suspension and brakes, diff, plus the mods required for the trans tunnel and radiator support panel so I can fit the intercooler and allow better flow for the radiator. I still have a lot of work to do, so I would like to have in my mind (and on paper) a clear direction of what I want to do and the Engineer can determine whether ot not he thinks it is suitable or at all achievable??
I see you have been down a similar path? If you have any advice I would certainly take it on board. Thanks.
Posted on: 2013/10/25 5:47
From Melbourne, Australia
the main thing with the wheel bearings/strut swap is getting an engineer to sign off the use of larger wheels or increased track
if your using struts from a car that had those wheel diameters or a wider track then the engineer can be confident that this is ok on your car without needing to do calcs or in-depth analysis
which engineer are you using?
Posted on: 2013/10/25 10:36
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From MOOROODUC. Victoria
I think you would be wise to visit one of us that have either finished or are a long way down the track. That would give you an idea of the complexity and cost that you'll face. I found with mine that it became a lot like the children's song "there's a hole in my bucket dear Liza" --- one decision led to another and then another, which is ok for me given the result; I have a daily drive that's my own creation and I like driving it. If I had it to do again I would do it differently (but 20:20 hindsight is a wonderful thing).
I am happy to offer you to see my car if you're near the Mornington Peninsula - I don't think i will get to the Datsun day on December 1st.
David
Posted on: 2013/10/25 22:20
David, unfortunately I am out in the western suburbs of Melbourne but would take the trip out as for a few hours drive it could save me a lot of head aches with the build. I would especially like to see how you have gone about the trans tunnel modification.
I am speaking with Talk Torque for the engineering. The only problem that I can see is that he hasn't done this conversion before. A few guys on this forum have mentioned someone in Dandenong that has done a few ca18det 1200s I might even trynto get onto him?
Where is the datto day in December? I would love to come along.
Posted on: 2013/10/26 0:29
« 1 (2)
