Browsing this Thread:
2 Anonymous Users
Re: racetech's 1200 SR20VE Project |
From Cape Town, South Africa
June 2013 - Datto TransformedOnce you get the idea in your head that if you finish this and that in order to drive the car in months, things start to slip, and that is exactly what happened with this update. Once I realised I had finished with all the machining on the front suspension I started to put it together to take it for a spin. Alternative to CounterboresDuring this machining phase I learned a lot about working with the Milling machine and lathe, but one of the biggest surprises must have been the use of flat wood drills as counter bores on aluminium, mild steel will destroy them in a heartbeat. On aluminium they work a treat, you just need to take your time and keep your head with drilling the correct pilot holes, even the finish is pretty good for a R30 tool. Wheel SpacersI had to leave these to the end, in order to get the correct measurements done with the struts mounted. The idea with these is more or less exactly the same as the Escort rally boys with wide arches, you mount the struts in such a way that you can adjust them to 0 camber, then make a spacer accordingly to fill the arches. My units serve a dual purpose, I made them to except standard sized spigot rings and also opened the centre hole up to allow myself to mount another dust cap if I feel the need one day. The lathe work kept me busy for a while, but drilling the holes consumed a whole Saturday, finishing a hole required between 5-7 tool changes before moving on to the next hole. SteeringFirst order of business was to source a set of Cressida Rack ends and Escort MKII Tie Rod ends, the tie rods was chosen due to their standard M14 thread and the fact that they use the same taper as the struts. Seeing that I have no idea how to cut thread on the lathe, I bought a decent M14 die and turned a nice tool holder to use it in the lathe. It took me under a hour to cut the rack ends to size and cut the thread on both of them. Building the steering arms was another beast altogether, these took some time but is not the final product, as I first want to use the car to figure out what needs tweaking were. The next set will be built with the tie-rod mounting higher in order to allow more downwards strut travel. Wheel Speed ProbesSince I needed a wheel speed input from the front wheels, I decided it is time to import probes for a rally ODO. I made some brackets and installed a probe on each strut, one for a ODO in the future and another unit for the LinkECU to calculate the difference between front and rear wheel speed, this will be used for the traction control function. Rear CoiloversStrut AssemblyAfter all the parts was powder coated I started with the final touches to assemble the struts, had to countersink the steering arm mounting holes seeing that I had to use countersunk cap bolts as normal units was hitting the bolts connecting the hub to the rotor adaptor. Final assembly went without any hassles.
Posted on: 2013/8/6 14:53
Edited by racetech on 2013/12/23 11:24:30
From Logan, QLD
That work looks awesome, I'm jealous of your budget and skills for the car stuff :). But I don't get what slipped in your post?????
Posted on: 2013/8/6 23:43
It's been a long road to get the car to the state that it currently is in, especially the last few months was tough, everything started feeling like work, but that is the case with so many things in life. Luckily for me the list of things to do was starting to shrink, well I was hoping for it, as one thing was finished the next one came up. Do not get me started on wheel speed probes. Radiator Air DeflectorSeeing that Air Temps was quite high the previous time the car was at RAW, I had to bring these down to acceptable numbers, something in the region of 2-5 degrees Celsius hotter than ambient when traveling. Previously the biggest issue causing the high intake air temps was due to the location of the oil cooler directly in front of the air filter. First things first, I moved the troublemaker away from the air filter for obvious reasons, I'm quit limit with options for mounting the filter. Seeing that I had some space next to the electrical fan in front of the radiator, this was the obvious location. To further provide the air filter with cold air, a deflector plate was made to bolt to the radiator in order to divert hot air from the oil cooler and radiator away from the air filter. Up till now looking at the logged data from the ECU the results are quit good and the temps stay at +-3degrees from ambient. Steering StopsAfter the first few drives with the new front suspension it became very obvious that I will need to install some sort of steering stops to limit the amount of steering angle as wheels were starting to rub. This was quite easily taken care of with some lathe work and a few pieces of flat iron and tube with a threaded insert to adjust a bolt. Potential Mud flap PositionsDuring one of my first drives with the new suspension I decided to drive the car to my parents place about 110km away on a Sunday morning, this would allow the various parts to start settling and provide me with the opportunity to test a few things on the gravel road leading to their home. An added bonus was the fact that it rained the previous evening which left the gravel road with some wet spots which made for the best way to figure out where to fit mud guards in the future as the mud was thrown by the front wheels. Velocity StacksAt long last I managed to finish for of these, I either made a mess of the fibreglass work, or destroyed them in the lathe trying to get them supper smooth and the finish perfect, after destroying 2 in a matter of minutes I decided lets go with the operational finish rather that the display finish, at the end of the day they turned out quite nice. After they were bonded to the aluminium backing plates, I took the opportunity to make some retaining clips from thin Stainless Tig wire to keep the air box nicely secured to the backing plate and keep the dust on the outside. Dash Board & ElectronicsSince I had to make some changes to the wiring to add additional switches for the motorsport functions like launch control/traction control and flat foot shifting, it was decided to cut the dash in 3 pieces to make future work allot easier. With the old one piece design it was fine removing the dash, but reinstalling was a nightmare to say the least. Everything was marked and masked before cutting commenced, a piece of aluminium was shaped to act as a big washer behind the dash pieces to hold the rif nuts in place. This new 3 piece design allows me to decide which part I want to re move in order to work behind it, what a joy. Once the dashboard was done I picked a fight with the sheet metal that fastened below the dash that houses the igniter modules. These were mounted out of view as I hate looking at lights that is not warning me of something dangerous, but reality got the better of me and I decided to ditch the plate completely and mount them on the firewall box cover. In their new location they are slightly in view if you look down, which you should not do when having fun and trying to keep the nose going forward. Since my madevnology AX22 was laying in the cupboard gathering dust, I decided this would be the ideal time to mount it, just maybe Rezlo from RAW wants to use it for mapping purposes, the AX22 is quite a nifty GPS logger at a very affordable price for what you get, go look at the specifications on the manufacturers site. Another part proudly supplied by RAW. Coming to think of it, the majority of imported parts on this car was sourced and supplied by Rezlo from RAW (Rezlo Auto Works). Brake Bias AdjusterWhile the dash was out, it allowed me to remove the pedal box to install a smaller 0.625" master cylinder on the rear brakes. The old 0.750" unit was removed due to the weight distribution of the car dictated that more pressure is needed on the rear. Once this was done, I started installing the brake bias adjuster and finish the job off by cutting the adjuster cable to the new length. Once I played with the adjuster I learned with a shock that the car until then only braked on th rear wheels, once the adjuster was set to a a few clicks towards the front the pedal softened slightly and the brakes felt much stronger and balanced. I'm still not happy with the brakes and see a set of 4 pot Wilwoods replacing the current VW units. Trip to PE to visit RAWAfter a few gruelling weeks slaving away on the car to get it ready for its visit to RAW, it was quite a strange feeling of turning my back on the car and walking away from it at the Auto Carriers depot. Besides the exhaust, the car was never too far from me or a close family members eye. This time around it was going to be driven, loaded and transported by a complete stranger. You can imagine the joy when Rezlo phoned me stating the car arrived safely, but then he blew my bubble by stating that the Dash does not showing oil pressure. Luckily I installed an idiot light for this exact purpose as I still need to setup the dash completely. At this stage some people may wonder why I would send my car 800km up the road to be mapped by Rezlo, first off because of the ECU chosen for the application, I opted for something that would take care of all the decisions for me, if the oil pressure drops, go into limp mode or cut the motor completely. Let's look at fuel pressure, if for some odd reason the pressure drops completly I want the motor to be switches off completely as a fuel pipe could have burst and could be feeding a fire with fuel. All this sort of things the ECU should control and not me, coupled that to the man’s incredible talent and understanding of car tuning the 800km seems irrelevant, just another challenge and some logistics. During the whole mapping process I believe Rezlo mapped on a daily bases on the car, even went over and above and did some work at night time and some track work to make 100% sure everything is spot on. During this time Rezlo managed to send me a few photos of the friendly Metro Police letting him continue on his journey and one or two YouTube vids showing the progress. The car spend a total of twee weeks in PE and received all the attention it deserved. We were actually quite luckily timing wise, seeing that the weekend we went to collect the car there was some Regional racing on Aldo Scribante were Rezlo competed, at long last I can see his race car in action, and boy is this combination fast. We drove up to PE the Friday, arrived at Rezlo premises and marvelled at his projects and kept him out of work for a while. The first experience I had with the car was when Rezlo showed me how it starts, this is something wanted from day one, a racing car that starts like a factory car, ignition on, wait for the pumps to prime, make sure the neutral light is ON, turn the key and it starts, all this while standing outside, no throttle pumping or funnies here, just a decent ECU and an operator behind the laptop. We said our goodbyes and off we went, filled the car with some fuel and headed off to our accommodation, one off the first things that I noticed was the behaviour of the ITB's, I didn't need to throttle the car on pull away, not like a lot of people tried warning me "50mm ITBs on a 2 litre is not going to work, you will lose too much torque and will need to rev the motor to pull away, etc" non-off that. Just comes to show what decent ECU with proper mapping can do to the way a motor delivers power. I must say I enjoyed every minute off it, after 3 years I think I'm allowed to have some fun, and boy did I until the motor just lost power on a downhill just before Colchester. Seeing that I decided not to back a laptop I was quite stuck, managed to drive the car to the nights’ accommodation. The next morning my mood was quite shattered, but life goes on, I tried driving the car to Aldo Scribante, managed to get a few kilometres out of Colchester and then the car just started leaning out, stopped next to the road. By this time I was quit shattered and not in the mood to struggle with something I need to take apart to find a problem, hooked the car up to the A Frame an towed it to the track, after exploring the track and watching a few races, Rezlo even tried his magic, but it was definitely not plug related. After all this I was done, asked my brother and father that accompanied me on the trip if we could leave for Jeffrey’s Bay as I was in desperate need of some rum and coke. The next morning we left for Cape Town and as lady luck would have it, again we had issues at the Toll Plaza just before Port Elizabeth, they are too shallow to interpret laws issues by the government, they rather follow their own set. Once home it took us less than an hour to find the problem. Can I just say thank you for onboard Data Logging and in this case LinkECU, if was not for logging I would not have seen that the fuel pressure constantly dropped, until nothing, then it climbs again and starts dropping off again, suggesting some sort of fuel delivery issue. First things first, get the 30 litres off fuel out of the tank in order to strip the system to find the culprit, now the easiest way of doing this is by removing the pipe that returns to the main tank out of the surge tank. Once loosened it is placed in a container and the low pressure pump switched on to drain the main tank, but in this particular case nothing came out. Luckily for me this narrowed down the possible location of the issue. Removed the pipe between the main tank and Holley pump and all that came out was a small trickle of fuel, which is not correct. Looking at the fuel coming out I noticed some black particles, removed the tank and drained it via a pipe thru a piece of cloth and found all sorts of black particles. Still not 100% sure what the cause was, my brain was starting to put the puzzle together, after collecting the car I filled the tank and noticed the new neoprene gasket between the filler and tank was pushed out more than usual. Once I removed the filler the cause was quite obvious, what was sold to me as neoprene was most definitely not, as the fuel attacked this rubber and started breaking it up and smaller chunks and even dissolved some of it. All of a sudden the puzzle feel in place, strange how the mind works, on our way back from PE the previous day I deceived a plan to fix the filler to tank issue by turning flanges that seals with a o ring, and here I was standing and that plans seems like the only thing needed to solve the issue, besides new filters and a complete flush of the fuel system.
Posted on: 2013/10/29 12:59
Edited by racetech on 2013/12/23 11:22:40
[quote="townie"]But I don't get what slipped in your post?????
I do not understand what you mean with slipped in your post.
Posted on: 2013/10/29 13:03
Oh the joys of custom cars. Great stuff and now waiting for your first event. Congrats
Posted on: 2013/10/29 20:59
unfamilia, I do agree with that statement, but I see it as a learning curve, everything I redo I try to make more accessible and easier to work on in the future.
Currently the fuel tank is in pieces waiting for some attention.
I'll be the slow one at the back trying not to bend the car on it's first outing.
Posted on: 2013/11/12 9:53
Datto Build - November 2013 - Wings and Wheels 2013What a busy time of the year, or is it just me, maybe, but the last few months was crazy, fixing the fueling issues, trying to get the car ready for its first official public debut at the 2013 Wings and Wheels Air show and fixing my biggest fail on the car to date, not that it was any easier last year, last year I was trying to get the car ready for roadworthy. Let me share with you the last few months, as you would remember the car returned from Port Elizabeth with a fueling problem that was diagnosed with the help of decent management. Fuel TankWhile I knew exactly what the cause for the fuel starvation was, I had to figure out how far the small pieces of rubber traveled, I basically took the whole fuel system a part washing and flushing everything out, luckily for me I did not find any pieces of rubber on the outlet side of the first filter. I even went so far as to cut the whole filter open to make sure this thing did its job.</span> After a quick visit to the local metal shop I walked out with two disc and a piece of round bar as pipe is only sold in this country in 6m lengths, which meant I was going to make a pipe out of a solid bar of aluminium, coming to think of it, quite retarded, but this is Africa and we should make do with what is available. The plan with these were to turn two flanges that will seal on top of each other with a nitrile O-ring between them, seeing that nitrile O-rings is not unobtanium, this should be a good solution. Once all the work was done on the lathe, I drilled the holes to be tapped with M6 thread and this is where I made my first mistake as I would discover later on, which also led to a total redesign of the fuel tank. Everything was welded by my trusted aluminium welder called Gerrie, this man is probably going on holiday with all the money I have so kindly donated to his power bill over the last 2 years. Once everything was assembled I could at last enjoy the car, well until I filled the tank for the first time to capacity and noticed that the fuel is still leaking past the bolts this time, you remember what I said earlier, well this is it, I opted to drill the holes thru the bottom flange for tapping, because the flange was just welded on the outside fuel was able to seep thru the holes as they were on the outside of the O-ring, well just another fail moment that I learned from. All in all this only meant I have some more thinking to do, not fill the tank and finally enjoy the car, I would just like to say, thanks Ian from RAW for all the patience and the mapping of the car, what a joy it is to switch on the ignition, check that the neutral light is on, turn the key and it fires to life, idle control making sure idling is spot on without human intervention. Now to get rid of the crappy induction sound when the VVL is activated, it sounds bad, maybe it sounds better on the outside, but in the car I'll rather listen to the navigator telling me how he is going to get rid of the oil leaks on his Ford. RimsSeeing that second hand 15" Dunlop Rally rubber is available and also more or less the only second hand parts filtering down from the National competitors, it is the obvious choice to use these if you want to keep running cost to the minimum. I opted to use genuine Volkswagen Microbus rims as there offset is good and they somehow looks the part as an old school rally rim. Yes and yes I hear all the critics going but they are 5 hole xyz PCD and it will cost a lot of money getting them converted to 4 / 100pcd, you could rather buy a set of rims of rims at the local "mag" dealer and it would be cheaper. First off all, in total I need about 16 of these rims so the proper Speedline/Compomotive rims are a big no no, secondly I'll rather use steel rims than buy these fong kong wannebe reps for xyz just to say I have rims. These rims are very well made and there construction is strong enough that I believe they will survive rally at my level. First they were send to Worcester to be sandblasted and then off to the "Aluminium Welder", again I could have spent halve the amount of money I so kindly donated to his holiday budget at a other place, but what is the use spending the time, money and effort searching for a strong rim and then throwing all away trying to save a few bucks, only the best welding on the old holes would be good enough. Seeing that we have bought all the necessary equipment to drill the holes, I decided that will be the way to go, even if I needed to make some decent extensions to allow the rim to fit the rotary table. Afterwards they were send to the "Wheel guy" for some TLC and a coat of white paint.</span> SeatsYou may be wondering what I'm about to do to the seats as they are already mounted etc., well the mounting part is the issue, get ready for this as all my friends are still laughing there arses off about this, but heck, how else will you learn. What did the oke with the clever words say; "It's not about how hard you fall, but how fast you can stand up.", well that is exactly what I did. Let me tell you what I like to call the biggest fail on this whole project so far. A while ago I was sitting in the car and my brother is like, "have you sat in the seat with a helmet on, seeing that there is not a lot of space between your head and the roof/roll cage". This prompted me the other day to get the helmet out of the cupboard, and get in the seat, well I was actually very upset once I learned this is a death trap and I started to make plans to get the seats mounted lower. First off all I had to remove everything in the car that could be damaged by the sparks that was about to fly from the grinder. Once everything was marked off the sparks flew, once the dust settled and everything cleaned, I measured the sizes of the holes and had some buckets cut & bend to make the hole job easier. A few months ago I imported a set of glecko and finally this was the opportunity to really use them and see if they are worth all the fuzz being made about them in the rest of the world, and yes they are worth every cent spend on them. Some strips of sheet metal was cut and drilled to form the basis to fasten the buckets to the gearbox tunnel. First they were tack welded in place, then fully welded on the bench, removed all the excess material, prepped, painted and finally installed, the one even needed a relieve for the exhaust as I wanted the most amount of space to get the seats lowered. Finally I made some quick high adjustable feet in order to measure each brackets height exactly as the cars floor is not the same height. After taking refitting each seat probably 15 times all the brackets was done, with only one of the 4 brackets per seat being mounted permanently, you will also notice 5 holes 12mm apart, they were just added for possibilities, currently I have the navigator seat installed at the lowest possible setting and the driver seat at the second hole from the bottom as the extra 12mm does help with visibility all this sitting very low in a car is very new to me. All in all the seats ended being 80-100mm lower than previously, this means about 30-40mm clearance with a helmet and roll bar padding sitting very upright, a lot of work further, but I'm happy. FAIL eliminated. Steering WheelObviously by lowering the driver’s seat by almost 100mm will have a few knock on effects in regards to the steering wheel location and then the steering column switches and then the digital dash and then the cover for the dash. How does the saying go: Life is a journey, well lowering seats is also a journey. I'm not going into huge detail on his, but I basically turned up some aluminium spacers, milled them to the correct angle in order for the steering wheel to sit low enough but also at the correct angle.</span> Once this was done, it was time to move the bracket holding the screen and switches in place lower, this was done by adding an intermediary mounting plate between the dash and bracket, cut away some metal, made new screen mounts and went to work making a template for the cover over the screen, it was then traced down on a piece of paper and proceeded in making a CAD drawing of it. The cover was plasma cut out of 1.5mm aluminium and sprayed matt black to blend in with the rest of the dash.</span> FlaresJust after I picked the car up after mapping my father and brother took a few pictures of the car from behind as this was the first time that one of us was looking the car from behind while on the road and the white flares stuck out like a sore point. Since the last update Car, Boat & Truck Mechanical & Bodyworks came on board as a bodywork sponsor, they will keep their eye on all bodywork to keep Datto looking neat. The flares was removed cleaned and dropped at the owner Chris Gillomee, Chris quickly knew exactly what I had in mind and jumped at the opportunity to mix up a special batch of Matt Black, a few days later the paint was cured and on first site I was very happy, the relationship between matt and a slight sheen was perfect, thanks Chris and the whole team from Car, Boat & Truck Mechanical & Bodyworks out in Triangle Farm that made this possible. Please give Chris Gillomee a call if you need any bodywork or mechanical work done on 021 945 4105. While you’re at the shop ask Chris to show you his pet project Tiger 1. I must admit, I'm very happy I took the plunged and changed the colour on these, the matt looks at home. Wings and Wheels 2013Well well, what can I say, while all the above was going on I was invited to display the car at this year’s Wings and Wheels air show, for me this was quite an invitation as someone out there is recognizing the time and effort that is going into this little car, needless to say I even went so far to re install the old seat mountings just to attend a pre shoe photo shoot, about 4 hours of work just to get the car roadworthy, cleaned and able to drive there. The car even performed better than the Golf's, as you can see in the photos, the one group tried jump starting the one no less than 3 times, the other group tried keeping the oil between the sump and Spiderman’s feet. All in all a very fun day. Seeing that this would have been the cars first public appearance in front of thousands of people I worked my arse off to get everything as I wanted it, this meant after work each day at least 4 hours, every Saturday and Sunday, it felt like work, the fun was removed, just job after job and no joy. ..........................................and then the xxxx hit the fan, the event was cancelled, at first I wanted to shoot some wise ass politicians plane out of the sky, as the word on the street was that the show was cancelled due to political reasons, well to this day it is still not officially known why the event was cancelled. My heart goes out to all that helped organize the event to the point (a week or two before the event) where it was cancelled, what a slap in the face. Thanks for the invite Patrick Vermaak, next time.
Posted on: 2013/12/20 11:01
December 2013 – Rally PrepSince the car returned from Rezlo in Port Elizabeth, I'm pretty sure the fuel pump circulated more fuel between the two tanks than through the fuel rail. Which is actually quite a pity as the car is so nice to drive, but there is work to be done which take priority over driving. Fuel TankThe last month or two I was quite busy with a few things, one being the fuel tank which received a complete redesign. First the top cover was completely cut off to expose the internals, which was nothing more than a piece of foam. With the current worked planned for the tank there were 3 things important that needs attention namely: 1. Fix the leaking remote filler flange that is welded to the tank - this was an easy one, it just needed some welding on the inside which was previously inaccessible. 2. Design and install an internal surge tank, which will eliminate the need for the noisy low pressure pump. 3. Install a separate fuel level tube which will enable me to have more accurate fuel level readings 4. Then slow down the movement of fuel by installing baffles. The idea for the internal surge tank came from the LocostUSA Forum one of their members stumbled across the idea after seeing the inside of a Honda S2000 fuel tank, it is basically a maze were the fuel can enter but not exit without following the maze outwards. While I was at it, I also decided to remount the fuel sender lower in the tank to read more accurate low levels than full and fit a baffle tube around the sensor with a small hole to be slightly more accurate while the fuel is moving around. Since the tank was open, I opted to add a few baffles to slow down the fuel movement in the tank. Since the surge tank is now located within the tank, the low pressure pump was removed and the pipes had to be redone, this time around all in AN push lock fittings and pipe. Boy I love these AN fittings, but they do have the tendency to ruin the amount of spending money left. I do like the look of the new design, very clean and tidy. Hopefully the tanks works well when the fuel is on the low side, otherwise it will be back to the drawing board or re installing the surge tank. Strut BraceDuring the design of the fuel tank, I also included the drawings for the strut brace mountings. Quite allot of plastic and paper sheets was sacrificed to get to the final design that would clear the air box and plumbing. The next best thing after billet parts is parts that is welded by an expert and not covered or smoothed away, these are some of them. Some would say they are overkill, but I think they would do the job. Mud FlapsThe mud flaps being the most important item on the to do list before rallying the car, work had to start. First I stumbled around with a few ideas of mounting them, had some strips metal cut, and obviously once I started everything changed. At the end f the day I settled for a very simple but effective way of mounting these, I just hope it does not destroy the arches, only time will tell. First I made a bracket that fastens to the arches on the one side and the other on the inside of the wheel arch. On the mud flap itself I made a mounting bracket to hold on to the flap and then fastens to the bracket a<span style="line-height: 1.5;ttached to the vehicle. This way I can adjust the height of the flaps by just making a new back plate. Then the flap is pulled away from the wheel with a single bolt to not damage them. This is probably going to be the headache area, but we first need to use the car before I can judge.</span> A few small thingsSince head room is a issue, but since the seats are mounted lower it is better, but I'm still not willing to waste space, I found some older roll bar foam which is thinner than the newer designs, these were used everywhere above the head. Finally the rest of the roll cage that could come in contact with body in a accident was covered with the newer design padding. A set of Wilwood Polymatrix A compound racing pads found their way into my hands. Changing pads on these callipers is a joke, it takes longer removing the wheel than swapping the pads. These pads are magic, very good low temperature friction and good high temperature friction with minimal fade, just have a look at the comparison chart from Wilwood: http://www.wilwood.com/BrakePads/Brak ... x?compound=PolyMatrix%20AWARNING: I do need to warn everyone considering using these stuff, it is a nice pad, but I would not suggest these for non-motorsport use or any usage were a helmet and balaclava is not used as they squeal very badly, so bad you will not know when they are worn out as it sounds like metal on metal constantly while braking. Imagine you stand on a train platform and the train stop, take that squeal, times x 3 and you have an idea how bad these are. Maybe another way of bedding them in will help, but I'm not convinced. I also had a navigators footrest bend, this piece would have a double purpose, one being to provide my navigator with a nice even surface to keep his feet on and the other to form the basis to mount a cover over the fuse/relay box. But from the pictures I can see that the right support is going to become a challenge. My brother also told me the one day that the car is way too soft. I decided to remove one of the 3 exhaust boxes, since I had spare flanges cut a while ago it was just a matter of removing the box and make a pipe up that replicated the old box. I must say, even with this box removed the car is still very soft. I also managed to mount the tow hooks for that difficult situations.
Posted on: 2014/3/13 10:55
FEBRUARY 2014 – RALLY PREP IIIn this update the car is transformed into what actually looks like a racing car and not a very wide arched road car with a roll cage. I don't know about you, but this thing looks damn good and I'm quite proud to be the owner of it and privileged to look at it every time I open the garage door, even thou there is still a million things I'm not happy with, at least it is in a state I can start to enjoy it and that is on the gravel fighting the forces to keep it in a straight line once I need a break from the forces trying to dirty my pants, let us forget about the new dictionary of swear words I learned during the build of the car and start wagging the tail around.</span> Sill Stands & BracketsThis being phase II of the sill stands due to the fact that I shortened the original stands as they were stupidly high and no jack in the Cape Town surrounds could lift it that high. In order to make it more practical but still at a comfortable height to work under the car they were shortened by 100mm. The bottom sill height from the ground once they sit on the new shorter stands is still +- 500mm, which make working on the car quite nice. You will notice all the supports in the final product, first thing you notice is the top plate with the big hole, this piece also incorporates a little bucket to store wheel nuts out of the gravel once removed. The bottom part is strengthen with a plate on both sides, then the pin is supported with two pieces of plate to aid with the weight distribution. Keep in mind these stands must be able to support at least 300-400kg depending on how even the ground is. I have tested them with the full weight of the car plus driver with only 3 stands touching the ground. While all this was going on a set of brackets was also finished to bolt to the underside of the car, as I did not add these brackets while building the original car, I was not willing to weld on the sills, thus the brackets. All of the parts was epoxy coated by Metalseal Coatings in Parow with the same red as the front suspension parts. Since working with these will never again build my own racing cars without the ability to use these, no more crawling under the car to position trestles just to re adjust them as you lower the car. These you jack the car, stand next to the car while inserting the stands, yes you stand, lower the car, jack the rear, insert stands and lower, no more laying on the ground while looking lowering the car. Strut BraceAfter spending almost an hour waiting for these strut mountings too cool down after the welder finished with them I could mount them and start planning the strut brace. Since we acquired our license for the popular Bend-Tech software, I was quite amped to test it on some in the real world but still simple enough to not waste a lot of steel, and the brace was the perfect job to test how accurate the software is, with confidence I can state that this software is and will be an assist in our garage for years to come. After everything was measured and designed in the application, it was a matter of marking the tube and bend as instructed by the software, once the tube left the bender the application provides the profile for the mitre. In my case the brace were to mate with a 25mm bush on the mounts, whipped out a whole saw and completed the mitres on the mill as the application instructed. The fit is perfect, I would recommend the software for anyone willing to learn something new to make their projects more accurate and easier. Brilliant piece of kit. Mud Flap ChainsSeeing that the mud flaps were mounted with rally tires in mind, I had to make some sort of plan to raise them when using normal street tyres on the car. Eventually I settled on some small brackets I had cut and after welding, electro polished for a clean look. I used some 2mm cable and small snap hooks to attach to the brackets, raising the flaps enough to stay away from the wheels when reversing. Wheel ArchesWhat an epic fail. Let me explain, as I was fitting the mud flap chains, all I could think of was taking the car for a spin on rally tyres for the first time, for me this was a big thing, well this big thing turned into a nightmare as I was driving down the driveway and the wheels caught the mud flap mountings and barely missing the front part of the inner arch. I was so focused on making space for the wheels to turn in front that I did not spend enough time on the back. This ended up in stripping the coil overs, marking the arches and removing up to 30mm of bodywork just to move the mud flap brackets backwards. Redesigned the mounting slightly and replaced all the normal bolts with button head Allen caps, all this for more clearance. The flare was also moved back by about 25mm. Once all this was done I had to make new pieces of flare that would be attached to the flares to fill the 25mm wide gap. This job was given to Car Boat Truck Mechanical & Bodyworks, they also managed to clean up the arches. Off-road Jack BuildSeeing that my old aluminium jack wasn't up to the task to lift the car high enough to insert the sill stands, I had to purchase a new jack with a longer stroke. Since seeing my first 4x4 jack at one of the Adenco 400 off-road rallies I just knew I had to add the <a href=" http://www.madev.co.za" target="_blank">Madev.co.za</a> touch to this one as the standard wheels was just not good enough, well I ended with a set of front wheels rolling on two bearings each, the rear units was package for me in order to have a smaller mounting but still keep the bearing wheel. A few bushes further and the front wheels were mounted. The rear wheels was not that easy as I needed new mountings as the wheels was hitting the body of the jack when swivelling. I made some new mounts and had some extra supports welded on. The jack works very nice on all sorts of surfaces and is supper quite, only problem is the fact that you have to keep an eye on it, if you do not park it really good it will literally run away without you knowing it. Next steps for it is to make some lifting shoes with rubber that is the correct height to avoid using spacers between the jack and the body of the car. DecalsSince the beginning of the car the paint scheme was set as being something in the line of the old BRE Datsuns, seeing that I like blue much more than red, going with a blue roof was a no brainer. Having completed the majority of the mechanical work it was time to start with the stickers. As I'm not that creative, my brother helped a lot with the vinyl. Sizes was a very important thing as we started looking around a little and noticed way to much small high detail work on other cars that just disappear with distance and speed, we opted for the simple and big approach for the stripes and numbers, the smaller stuff will be visible at speed and distance but not readable, for that I invite you to come a little closer. A few smaller changes will be made when time allows as white pin striping around the black numbers and a few smaller support stickers. Odds and EndsDimple Dies, don't you just love the way a few dimple dies in a project can set it aside from others, I just had to start playing with making my own as I do not know a place in the country selling them. A little more changes and I'll have the math all worked out and be able to make a full set. Oil Pipe, since helping a client with his racing cars plumbing, I ordered a few more fittings and replaced the oil feed from motor to remote filter with a lightweight nylon braided pipe. Suspension Limiters, as I have so much suspension travel I have to limit the travel in order to not damage the CV joints and rack ends, as a temporary answer I crimped some 2mm cable to keep things from travelling to much. I'm well aware that this is a temporary answer and will have to be replaced with something more robust. Rally Jack, seeing that I now have sill stand brackets in place on the car, I have a wider scope for sourcing a OEM type of jack with a huge stroke to lift the car in rally configuration in one go, the answer came in the form of a BMW E36 unit that needed only slight changes to fit my brackets. As you can see here it works nicely with the 13" wheels, only time will tell if it will work on the 15" rally wheels. Polycarbonate Windows, all the polycarbonate needed to replace the side and rear glass arrived, even the polycarbonate air vents arrived from the UK that will help keep us cool and also aid in pressurizing the cabin to keep the dust at bay. This will only happen the upcoming months as time is limited. All this will mean I need to redo the stickers on the rear windows. But seeing the ProSigns that originally done the current ones are too good to answer emails or phone calls. I think they should rather close their doors or learn to read emails. Probably filthy rich as they don't need business. The owner of Sticker King in Durbanville agreed to help me out with the new stickers as he heard I was struggling with the likes of ProSigns, thanks a lot Lourens. What’s next: the first rally event will be at the end of March on my birthday, how lucky can I be, hopefully we will be able to do some testing on the track and on some actual gravel before that.
Posted on: 2014/4/11 8:51
DATTO’S FIRST TRACK DAYSaturday we took Datto to Killarney racetrack for it's very first test session during one of their Track days. We probably could not have chosen a better day to do testing especially if the goal of the testing was to make sure all temperatures stayed within the limits while driving the car hard. The weather reports stated it was 34°, all I know it was 30° that evening at 12 o'clock. It was extremely hot and seeing that one of the things that we wanted to test was our safety equipment. A two layer race suit, Nomex balaclava, racing shoes, gloves and helmet does create a oven like feeling when sitting still in the car while not moving, once you are moving along and shifting up and down thru the gears, the heat is non existent, check for clothing being comfortable, just need to figure out a way to get out of the suit. The mechanical side of the car performed perfectly. No vibrations, no strange noises besides the high pitch sound when the cams is activated, just for the record, I hate this sounds the SR20VE motor makes with the activated sound, probably the reason why they did not fit this motor to allot of every day cars, luckily for us we had helmets on a the sound of a decent in helmet intercom distracting us from the sound. We had no issues with water, oil or powers steering fluid ending on the outside of their intended containers. The temperatures stayed with in limits and quite low in my opinion, I could just consider fitting a thermostat with a lower opening temperature rating. Highest Readings: Oil Temp: 98° Engine Coolant Temp: 87° Intake Air Temp: 37° Brakes, besides the sound these Wilwood Polymatrix E compound makes, brakes are very strong with the ability to out brake a few cars. The squeal on these things is terrible, before the track day, they only squealed while applying the brakes very softly, like coming to a stop at a robot, but after a few heat cycles on the track they squeal permanently, especially under hard and soft braking but not at moderate braking, as they want to tell you navigator when you aren't hard on the brakes. The suspension felt good, I was able to quickly gain confidence in the handling and start pushing into corners, in the high speed corners the car felt great, even when pulling the handbrake thru Malmesbury corner ( a high speed combination of two corners that is driven as one, seeing they follow each other closely), once you feel the back break loose just apply a small amount of counter steer and feed in the power and the slide is easily controlled, needles to say my navigator was caught by surprise as his instruction to me was take the corner I felt the most at ease with, he did not realize that was my favored corner. The only problem was what we expect to be a bad Lambda sensor which in turn provides the management with bad data resulting in a lean air/fuel mixture while using more than half throttle for longer than 2-3 seconds. The strange part to it is the fact that the injector duty cycle seems normal for the amount of load on the motor. All in all I'm very satisfied with the overall reliability of the car, it seems that the car could go for hours on a end, the only sad part is the fact that I could nor drive the car full throttle as I would have liked, but the time will come. It is a nice feeling to stop the car in the pits after the last round, get out of the race suit and drive the car home. Now that I'm happy with the reliability, it time to sort the small issues and hit the gravel for some real fun and games.
Posted on: 2014/4/11 8:52
