rubber gear shift boot
From BlueMountains NSW
I am after 3 (three) gear shift boots for inside the my 120y's just under console.
Mine have which have split due to being over 30yo have 4 expantion rings an a slot on the 4th or lowest ring to fit into floor plate.
the one on Ebay are not the same.
any one had same problem. cheers Bazz
ps happy to buy from outside aust if I can get detail of the item ....have already had people say they have em only to be different altogeather
Posted on: 2013/11/10 5:35
Edited by bazdat on 2013/11/10 6:53:13
I DON'T LIVE IN THE PAST....I JUST TAKE DAY TRIPS
Re: rubber gear shift boot
Buy direct from Nissan for lowest price
You want the boot that fits the tunnel hole? or the transmission shifter boot?
32862-G1200 BOOT RUBBER C/L $4 USD
74963-H5000 $30 USD
110mm diameter overall
15mm: lever hole diameter
85mm: floor opening diameter
Posted on: 2013/11/10 6:01
I am after the tunnel hole type lower photo not the inner boot on the top.
Do Nissan USA still supply these, if so I will try and get the aust branch to import some. cheers Bazz
Posted on: 2013/11/10 7:01
I.bought some 2011
Posted on: 2013/11/10 8:39
