Re: Help!! My a12 tries to kick over but won't start
From oregon in the usa
It "bucks" so it is getting spark and some fuel. As it then fails to start, begin by checking its timing with a timing light.
You have now performed an easy test which results in a quick clear answer which will usually either find the problem or tell you the ignition is ok.
[Note that an intermittent connection to the coil, points or ballast resistor can keep it from starting even if timed properly.]
If its ignition timing is ok, and the wiring is ok, then move on to other things which could be wrong.
You could put some fuel on a cloth around the aircleaner, and if it starts and runs a few seconds you have found a fuel problem. This procedure is dangerous, so do it outside and have a fire extinguisher there(preferably C02 as that does not dirty up the engine).
Posted on: 2013/11/11 5:48
Subject Poster Date
     Help!! My a12 tries to kick over but won't start Smitty93 2013/11/10 10:38
       Re: Help!! My a12 tries to kick over but won't start Anonymous 2013/11/10 10:49
         Re: Help!! My a12 tries to kick over but won't start Smitty93 2013/11/10 11:59
       Re: Help!! My a12 tries to kick over but won't start sunnyhaus 2013/11/10 16:28
         Re: Help!! My a12 tries to kick over but won't start ddgonzal 2013/11/10 17:20
           Re: Help!! My a12 tries to kick over but won't start Skremn 2013/11/11 0:03
             Re: Help!! My a12 tries to kick over but won't start Smitty93 2013/11/11 0:26
       Re: Help!! My a12 tries to kick over but won't start dennisg 2013/11/11 5:48
         Re: Help!! My a12 tries to kick over but won't start Smitty93 2013/11/11 9:37
           Re: Help!! My a12 tries to kick over but won't start levey 2013/11/11 11:17
             Re: Help!! My a12 tries to kick over but won't start clyons8 2013/11/11 20:02
       Re: Help!! My a12 tries to kick over but won't start Smitty93 2013/11/12 9:25
         Re: Help!! My a12 tries to kick over but won't start Anonymous 2013/11/12 10:10
       Re: Help!! My a12 tries to kick over but won't start Skremn 2013/11/12 11:37
       Re: Help!! My a12 tries to kick over but won't start levey 2013/11/12 13:04
       Re: Help!! My a12 tries to kick over but won't start loosekid 2013/11/12 21:57
         Re: Help!! My a12 tries to kick over but won't start Skremn 2013/11/12 23:37
           Re: Help!! My a12 tries to kick over but won't start a12grunt 2013/11/13 7:29
       Re: Help!! My a12 tries to kick over but won't start benny 2013/11/13 8:04
       Re: Help!! My a12 tries to kick over but won't start dennisg 2013/11/13 16:37
         Re: Help!! My a12 tries to kick over but won't start loosekid 2013/11/14 4:04
       Re: Help!! My a12 tries to kick over but won't start dennisg 2013/11/14 7:31
         Re: Help!! My a12 tries to kick over but won't start shanepickett 2013/11/14 13:14
