Re: Help!! My a12 tries to kick over but won't start
hey mate,
Just a suggestion,
Try and check/confirm that the wire(usually black) which goes from the points to the power in the dizzy is not in contact with any part of the dizzy housing.(i hope that makes sense)
if the wire is even slightly in touch with the housing it will cause the car to crank but not start.That might also be why the car probably started and drove normally for a while after touching the points.
remove that wire make sure its in good nick and when re-installing them back make sure they dont have contact with the housing.there is usually a plastic "bit/part" which stops the wire from touching the housing.
also replace the condensor if u already haven't.
I usually add another bigger condensor from the peugout 504 to the a-series one and they run well.
Hopefully that was the problem...
cheers
Posted on: 2013/11/13 7:29
Subject Poster Date
     Help!! My a12 tries to kick over but won't start Smitty93 2013/11/10 10:38
       Re: Help!! My a12 tries to kick over but won't start Anonymous 2013/11/10 10:49
         Re: Help!! My a12 tries to kick over but won't start Smitty93 2013/11/10 11:59
       Re: Help!! My a12 tries to kick over but won't start sunnyhaus 2013/11/10 16:28
         Re: Help!! My a12 tries to kick over but won't start ddgonzal 2013/11/10 17:20
           Re: Help!! My a12 tries to kick over but won't start Skremn 2013/11/11 0:03
             Re: Help!! My a12 tries to kick over but won't start Smitty93 2013/11/11 0:26
       Re: Help!! My a12 tries to kick over but won't start dennisg 2013/11/11 5:48
         Re: Help!! My a12 tries to kick over but won't start Smitty93 2013/11/11 9:37
           Re: Help!! My a12 tries to kick over but won't start levey 2013/11/11 11:17
             Re: Help!! My a12 tries to kick over but won't start clyons8 2013/11/11 20:02
       Re: Help!! My a12 tries to kick over but won't start Smitty93 2013/11/12 9:25
         Re: Help!! My a12 tries to kick over but won't start Anonymous 2013/11/12 10:10
       Re: Help!! My a12 tries to kick over but won't start Skremn 2013/11/12 11:37
       Re: Help!! My a12 tries to kick over but won't start levey 2013/11/12 13:04
       Re: Help!! My a12 tries to kick over but won't start loosekid 2013/11/12 21:57
         Re: Help!! My a12 tries to kick over but won't start Skremn 2013/11/12 23:37
           Re: Help!! My a12 tries to kick over but won't start a12grunt 2013/11/13 7:29
       Re: Help!! My a12 tries to kick over but won't start benny 2013/11/13 8:04
       Re: Help!! My a12 tries to kick over but won't start dennisg 2013/11/13 16:37
         Re: Help!! My a12 tries to kick over but won't start loosekid 2013/11/14 4:04
       Re: Help!! My a12 tries to kick over but won't start dennisg 2013/11/14 7:31
         Re: Help!! My a12 tries to kick over but won't start shanepickett 2013/11/14 13:14
