A14 stock crank pulley
Im after a single stock V belt pulley from an A14
let me know what you have and PM me for details
Need to be A14 not A12 ones please.
Posted on: 2013/11/23 2:14
Re: A14 stock crank pulley
A14 and A12 use the same pulleys yet there are several kinds. Do you want a dual groove pulley?
Posted on: 2013/11/23 4:26
single v belt, I will get a pic of one
this A10 and A12 one in pic below is not the one Im after
http://i237.photobucket.com/albums/ff ... rislyons8/CrankPulley.jpg
Posted on: 2013/11/23 4:41
So a round-hole single-groove Crankshaft Pulley
Not the triangle-hole type
Posted on: 2013/11/23 7:12
YES!!!!! champion DD
Posted on: 2013/11/23 12:53
From Launceston, Tasmania
I never new they were different between A12 and A14. What is the difference apart from the hole shapes?
I checked my A14 and A12 and was surprised to find out they are different.
Can anyone answer my question?
Cheers, James.
Posted on: 2013/11/24 8:33
got a stock A14 here missing its triangle pulley which I gave away with a couple of late A12 bottom ends forgot it was on it.
Posted on: 2013/11/24 11:34
The triangle hole version is H10 - early A12
A14 uses pulley from late A12.
Posted on: 2013/11/24 21:08
Ive had more than a dozen A12 engines, seen countless A12 at wreckers for 25 years yet never seen a triangular pulley in anything but an A14, maybe different in the states???
Posted on: 2013/11/25 1:34
Perhaps I am mistaken. So check the casting mark - H10 means designed for B110 in Japan.
Posted on: 2013/11/25 4:14
