« 1 (2) 3 »
Re: CBR1000RR injector dead time?
From Adelaide
Some pics, it's all a bit rough being a work in progress so don't judge too harshly.
jpg  Engbay 1.jpg (167.48 KB)
11744_52947bd684e38.jpg 410X307 px
jpg  Engbay 2.jpg (150.12 KB)
11744_52947c14e004c.jpg 307X410 px
jpg  Engbay 3.jpg (148.51 KB)
11744_52947c4509dbf.jpg 307X410 px
Posted on: 2013/11/26 10:48
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
Now thats unique beauty thanks Dylan!
and congrats for going it alone
Posted on: 2013/11/26 10:57
Love the wooden spacers for the filters. Lol. Great set up.
Posted on: 2013/11/26 11:14
From Adelaide
Like I said, work in progress....
Posted on: 2013/11/26 11:19
I know. Truely good work. Reminds me of simons manifold but he had 1 tb not 4.
Posted on: 2013/11/26 11:22
Mild steel manifold?
Posted on: 2013/11/26 11:23
Nothing wrong with a bit of wood and mild steel, its heritage with a modern difference :)
What are the extra white connections on the ford coils? its almost like the wasted spark on the 8 plug nissan engines without the extra spark plugs?? electronics stump me everytime
Posted on: 2013/11/27 0:06
From Adelaide
The manifold is mild steel.
The white connections are earths. It's an EDIS8 ignition running of a trigger wheel in the dizzy. The EDIS coils are different to most in that the high tension side has each end connected to a plug. Most coils one end is earthed. I wasn't sure how closely the inductance had to match the stock setup so I used the stock coils for now. Later I'll look for something a bit more compact that I can mount somewhere else.
Posted on: 2013/11/27 0:11
is there any chance there's a bit of fuel drop out at low rpm/idle due to stuff all intake flow and that 180 turn? that'd easily enough lead to errative a/f readings.
I don't know whether to suggest this or not, but you could try passing an oxy torch over teh manifold (engine off, and insulation wrap removed) and heating the runners up and then starting it and seeing if it affected the idle, and if it then started to deteriorate as teh runners cooled back down. I'm not suggesting you get them glowing white hot or anything mind you!
Posted on: 2013/11/28 6:40
John McKenzie
From Adelaide
It shouldn't matter at steady flow but you raise a valid point. I'm not to keen on taking it all apart again just yet. I'll flow test my injectors first and try manually tuning it open loop. I haven't had time to get back to it this week other than a bit of time last night trying to get the MSII to do the injector test properly. I'm going to program a micro to do it instead, that'll be quicker.
Posted on: 2013/11/28 6:48
« 1 (2) 3 »
