« 1 2 (3)
Re: CBR1000RR injector dead time?
From Adelaide
Found a little time to tinker this weekend. I built an injector tester. Photos are a bit dark but pretty much the Adruino just switches the injector on and off.
I'm having an trouble with my adjustable fuel pressure regulator, it's a different pressure nearly every time I use it. Anyone suggest a good one? I might just switch to the second-hand non-adjustable OEM Bosch one for now.
jpg  Injector Test 1.jpg (147.61 KB)
11744_529ab0cc3e097.jpg 307X410 px
jpg  Injector Test 2.jpg (104.84 KB)
11744_529ab0e44c93b.jpg 307X410 px
Posted on: 2013/12/1 3:47
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
From Adelaide
Got a stable and smooth idle today with the tested flows inserted and turning all control loops off. So I have a starting point. The CBR1000RR injectors flow 240cc/min at 40psi. I measured a negative open time correction which the tuner won't accept so I just set it to zero and will have to compensate elsewhere. Away from idle that correction doesn't matter.
Posted on: 2013/12/1 8:49
Nice work. Was it the fuel reg?
Posted on: 2013/12/1 13:29
« 1 2 (3)
