I forgot to mention TopGear used colder plugs and avgas for his setup which is drawthrough rather than blowthrough so completely different beast to yours.
However ignition with e85 seems more complicated for idle, midrange and top end. For the link I put up the smaller motor setups use more ignition down low and decrease as the rpm increase. Maybe doesnt hurt to index the sparkplugs to the inlets as well?. Maybe only a possible gain of 1-2hp but it all counts.
Also what do you think is the deal with leaner 2 and 3 as I thought the equal length manifold design would compensate here unless the boosted charge is doing something funky and spreading out to the outer parts of the manifold runners therefore 1 and 4 getting more somehow. Maybe you need to use a square box over the carb rather than the hose straight on the throat as there could be some kind of bias in the flow pressure that spreads it more to 1 and 4.
From this info making the gaps larger might not be the right way to improve your setup as it recommends smaller gaps and 3 colder ranges for the plugs when using e85 and 7.25:1 air/fuel ratio.
The solution to this E85 pre-ignition problem is to run a minimum of three heat ranges colder than the heat-range that spark plugs would normally survive on gasoline. Cold plugs are designed to transfer as much heat as possible away from the spark plugs so they won't melt. Supercharged, turbo, or nitrous'd engines demand a nonprojected-nose spark plug, which minimizes the length of the spark-plug ground strap. While platinum and iridium plugs are very popular for mild street cruising, they should be avoided when pushing an E85 engine hard, such as on the dyno, since these materials tend to retain heat and could cause pre-ignition problems. Also, because the supercharger boosts cylinder pressures, we knew a smaller plug gap of 0.030 inch would help to get the fire lit. Very cold plugs tend to not want to start as well as hotter plugs on a cold engine, so if you decide to build a similar package, you will need to experiment with heat ranges by starting out cold and going warmer until you see excessive heat evidence in the plug. Read more: http://www.carcraft.com/techarticles/ ... iewall.html#ixzz2oaf3EFFL
CarCraft article
