Browsing this Thread:
1 Anonymous Users
Re: Datsun 1200 Sedan build ! |
From Rosewood, QLD
where is my sedan?
Posted on: 2013/6/25 9:41
1971 B110 sedan project. 2012 Nissan Micra daily.
From mandurah
Update
So ive been busy on the sedan , so far ive filled the hoses in the engine bay and shaved all the brake line tabs and stuff off as they look #OOPS# , hiding all wiring and stuff so everything had to go!
Bay is nearly done ,its in hi build primer now and is ready to be sanded as its getting oainted tomorrow !
Also fitted monolefs to the rear , gabreil airjacker shocks , and a 2 link/caltrac setup has been tacked into place but I still need to brace the floor where ive mounted the front brackets
Disc brakes have been fitted to the rear , r31 rotors , vs commy calipers , rebuilt , next ill be shortening the diff housing 15mm each side to allow for more wheel clearance as the seem that runs through the rear dor shut rubs on the tyre , and I dont wanna chop the shell up :)
Should have a set of ca equipt silvia brakes for the front and I can then start on makeming them fit my stanza struts
Ok pics!
Posted on: 2013/7/11 4:39
Were the shocks a good fit? I never heard back about post costs
Posted on: 2013/7/11 6:40
From mandurah
Yea mik perfect fit , nice and stiff even with no air in the bags , when I put 50psi in tye bags it is perfect ,no body flex pushing on the roof ljke my ute had , sits flat as , should be a good combo with the coilovers in the front
Posted on: 2013/7/11 7:45
77 1200 ute 77mm bore a15 ,12:1 comp ported and reconed h89 head fairly aggro cam ,billet rocker spacers twin 40mm solex carbs on bpro manifold MSD 6al2 with 2 step limiter 4speed 60a box hd clutch 2 inch exhaust locked 4:11 ute diff ...
From mandurah
Quick update
I recently purchased a AC/DC TIG welder and have been playing round on bits of stainless and mild steel in the shed
Slowly learning all the #OOPS# involved and will be doing alot of stuff on my cars soon !
Been so busy with my rodeo getting it engineered and building it to be an absolute animal , ive lost track of the datsun being the important one!
So I have done a little bit , ive shortened the diff housing 20mm each side to allow for the back wheels to tuck into the gaurds without bottoming out!
Ive got all my front end bits in primer and have 2 pac black for them , soon as those bits are painted I can put the front end back in , and start on the engine bay again :( I used the wrong hardener so it set and looked mint for 2 days then started bubbling and wrinkling up , sucks so mucj cos we put in alot of effort and were really happy with it , then for that to happen is a real downer
Ill put some pics up of my tig and progress on the dat , need to hook in and get it done , I really miss the noise of the motor and the way dattos drive , nothing beats em!
Posted on: 2013/12/26 0:03
From Rosewood, QLD
sits nice
Posted on: 2013/12/26 6:19
From Trinidad and tobago
Is it painted yet?
Posted on: 2013/12/27 12:52
'71 Four Door Sedan. A15 Engine + Lighten Flywheel. E15 Electronic Ignition 32/36 Weber EI Coil 4 into 2 into 1 Extractors 1 3/4 Exhaust Pipe Semi Flow Hotdog 60 series Gearbox H150 Diff.
Street Sleeper!
STILL LIVIN' THE 70'S LIFE !!
Interesting project, the work you have done is commendable.
Posted on: 2013/12/31 9:21
From mandurah
will put up a big post tonight ,so far I have
fabbed up a new manifold for the itb setup ive with painted the steering and suspension components 2pac black and are ready to reassemble engine bay has been sand blasted and primed in etch primer and the shell is now at lewers smash getting panel and paint work done
ive also purchased
new window and door seals hydro hand brake lever ally radiator and new hoses bonnet stoppers new carpet new cusco camber tops new front apron firewall grommets new e85 compatable fuel pump wolf 3d ecu tilton twin plate clutch
slowly getting there ,soon as I get my shell back all painted up I can go full noise and get it done pretty quickly ,hoping to get it done before my 21st birthday in October!
pics tonight
Posted on: 2014/7/14 6:46
From Western Australia
haha sounds sic, looking forward to pics
Posted on: 2014/7/14 6:48
1974 1200 Ute - Build
