Re: a15 camshafts ?
A15 camshafts are not unique. Early A15 used the same cam as early A14. But late A15 used the mid range rpm cam also used by various A12A and A14 engines worldwide.
If you want the most HP, you need to rev the engine high. So use the early A14/A15 cam which makes peak HP at 6000 rpm.
If you prefer to make more HP at 4500 rpm, use the late cam
Posted on: 2014/1/8 4:00
Subject Poster Date
     a15 camshafts ? krusty 2005/12/25 14:12
       Re: a15 camshafts ? darrenwilson 2014/1/8 2:44
         Re: a15 camshafts ? ddgonzal 2014/1/8 4:00
           Re: a15 camshafts ? D 2014/1/8 4:24
