« 1 2 3 (4) 5 6 7 ... 18 »
Re: Kermit the beat up Sedan
From MOOROODUC. Victoria
Have been busy cleaning and extending my shed but got around to sound deadening the inside (mostly) with some dyna mat type stuff off eBay. Also fixed most of the rust by welding it up and covering with body deadener (black stuff you paint on.
Pics may follow, job still moving ahead - slowly
Posted on: 2014/1/6 7:34
Engine bay is in 2k primer filler now
the rad support panel is just sitting in place at the moment ... not welded in yet I think I should install the old style tabs for the grill first
also cleaning up the front struts (got one pretty well done) - Yes the drums are going back on the front.
Does anyone know where to get the rebuild kits for the front 13/16 slave cylinders ???
PICS
jpg  Engine bay in primer1.jpg (54.30 KB)
8710_52cf415d17b06.jpg 648X388 px
jpg  Engine bay in primer2.jpg (57.45 KB)
8710_52cf416c0b71d.jpg 648X388 px
jpg  Front strut rebuild.jpg (55.96 KB)
8710_52cf417bb30d7.jpg 388X648 px
Posted on: 2014/1/10 0:41
From Western Australia
looking awesome!
getting a lot done quickly mate
Posted on: 2014/1/10 1:24
1974 1200 Ute - Build
From Armidale N.S.W
Looking sweet man. Couple things and hope not to sound like a know it all and also may have missed something. 1. Im confused about the painting radiator support panel separate part. The RSP as its commonly known is attached to the car the new bit you just fitted. The front Apron is the part that goes on later. 2. Just a tip if you weren't aware already don't paint body deadener straight on welds or bare metal at least use an etch primer first as body deadener sweats like tar on the road on a hot day. The rest you can work out Im sure, Moisture and welds Bad combo.
Posted on: 2014/1/10 14:05
73 1200 wagon SOLD
Most would have junked it and you sir are turning mutton into lamb. Do sam proud.
Posted on: 2014/1/11 13:09
Thanks guys. (Beejj, Andy, Mik)
Andy ... the black tar is actually under body sealer ... but I get what you're saying. Also I am doing it this way to make sure I get paint under the battery stand (I will be assembling soon and then give it a final couple of coats- the apron will go on after it is painted)
and Mik ... what can I say ... mmmmmmm laaaaamb
and back to my question - about wheel cylinder kits for the front drums ... neither Bursons or ABS could find a listing and my local Nissan would not even look saying 'Nissan don't hold parts for 40 year old cars' ... anyone got them elsewhere in Oz?
Posted on: 2014/1/11 22:09
decided to weld on the radiator support panel so although it pretty much looks like it did before it is now solid
i had to grind all the paint off all surfaces to get the spot welds to stick (I love my hand held spotty).
repainted the primer filler (after the etch primer) and resanded again .... now just waiting for the best day to do the 2k topcoat in the engine bay
Also picked up a rear door from Ivan (Cheers mate). It needs a little TLC but should straighten out fine
jpg  Spotty.jpg (89.06 KB)
8710_52e252a294eca.jpg 561X488 px
Posted on: 2014/1/24 11:46
From Armidale N.S.W
Hey mate. Can i ask where you got the spot welder and what sort of ball park price they are ?
Posted on: 2014/1/24 23:15
73 1200 wagon SOLD
$250 on ebay .... private seller, it was a bargain!
Posted on: 2014/1/25 7:52
Engine Bay painted in 2 pack soramame green
it's not easy being green!
jpg  Painted Eng Bay1.jpg (75.05 KB)
8710_52e85f589de92.jpg 641X335 px
jpg  Painted Eng Bay2.jpg (65.61 KB)
8710_52e85f6548db1.jpg 648X388 px
jpg  Painted Eng Bay3.jpg (52.15 KB)
8710_52e85f861f343.jpg 648X388 px
jpg  Painted Eng Bay4.jpg (64.89 KB)
8710_52e85f913ce2c.jpg 648X388 px
jpg  Soramame Green.jpg (128.50 KB)
8710_54f8f2aa3f0cc.jpg 781X483 px
Posted on: 2014/1/29 1:55
Edited by demacoz on 2015/3/6 0:19:57
