pulled head? off A15 for jetboat
From Nelson Bay (NSW)
Hi guys i just pulled the A15 head off and tryed to match it with the info from teck section but cant? My head is a oval port head with the only numbers on it (under valve tran) are 109 on one end and 168H on the other nothing else. the vavles are E 30mm and the IN 37mm the other thing that puts me off is the water holes were the inlet manafold goes are only two 3mm holes on one side and one on the other? every pic ive seen in here looks like its about 10-12mm hole is this a standard head or not and should i drill the water holes out or leave them alone. it also has the kidney shape chambers thanks guys
Posted on: 2004/5/18 17:16
Re: pulled head? off A15 for jetboat
From Christchurch NZ
That head should be fine.
The heads with the bigger holes are the GX ones, and although they are more disireable for performance they're not essential.
Posted on: 2004/5/19 9:25
Forced Induction!
