Fuel Filter
From Port Douglas. QLD
Just wiring up my fuel system for the ca.
Installed low pressure filter, but when lift pump activated....nothing...
Removed it and just tested the pump without filter, hey presto, fuel!
So I checked the filter and there is no flow through it, like a manufacturing fault of something. Tried sucking through it and its completely blocked.
Any one had this happen? it appears just the outlet is blocked. Its a ryco that came with my maddat fuel kit.
Posted on: 2014/2/9 6:29
1200 ute
ca18det
Re: Fuel Filter
just fixed it with a skewer.
Posted on: 2014/2/9 6:32
1200 ute
ca18det
Re: Fuel Filter
From Melbourne AUS
years ago i had an n13 sss and after replacing the fuel filter i was given an engine warning light with
a 'running lean' fault code. so yeah it does happen from time to time
Posted on: 2014/2/9 13:04
1973 B110 A12
