ELECTRONIC CUT OFF SOLENOID?
i have the a12 stock carburettor without the electronic cut off soleniod
does it still use the cable choke?
what difference does it make
also does it mean i cannot place this carburettor on my a12 without the cut off?
if so how do i install the cut off soleniod when i buy my new carburettor if it is needed
Posted on: 2014/2/9 5:57
Re: ELECTRONIC CUT OFF SOLENOID?
What?
* If the carburetor needs a fuel cut-off solenoid, it will come with one.
* A fuel cut-off solenoid has nothing to do with the choke.
* No A12 engine requires a fuel cut-off solenoid
Posted on: 2014/2/9 6:16
well theres this carburettor for sale and it has a electronic fuel cut off switch, and its for the A12 series maybe a later series
so would i be able to install that carburettor on my a12 and just leave the soleniod unconnected seeming it didnt originally have one?
http://www.ebay.com.au/itm/Datsun-120 ... ories&hash=item338aa33212
Posted on: 2014/2/9 6:28
From Trinidad and tobago
That Carburettor is for the later aseries like a14/15.yes it cant bolt down as the orginal just a swap on.If you wish to leave it disconnected,Bypassing the Anti-Diesel Valve Unscrew the solenoid from the carburetor and take out the 'pin' in the middle. Then re-install the solenoid. Start engine to see if all is well.
It will no longer 'cut' the engine immediately, but otherwise the engine will run well with this pin removed.or
Yellow wire - fuel cut solenoid To general IG circuit (hot when key is Run or Start)
Posted on: 2014/2/9 7:00
'71 Four Door Sedan.
Street Sleeper!
STILL LIVIN' THE 70'S LIFE !!
im not to sure where the ignition wire is il have to find a chart, if anyone has a picture please send a link
thank you darrenwilson this is exactly what i needed, cheers
Posted on: 2014/2/9 7:09
Posted on: 2014/2/9 7:22
Street Sleeper!
my wiring is different to this picture, is there another way i would be able to find the ignition cable?
Posted on: 2014/2/9 7:55
Yes. Connect the fuel-cut solenoid to the ballast resistor.
Posted on: 2014/2/9 9:01
