Re: egi intake
From Central coast NSW
So have u checked for spark as well?
Posted on: 2014/3/22 23:02
Re: egi intake
the carbi was made in china do you think the jets might be different?
or for higher altitude
would i be able to use my old carbis jets?
i havent opened the new carbi or done anything with the jets
Posted on: 2014/3/23 3:14
Re: egi intake
Engine will start even if it has the wrong jets.
it seems like its not sucking in any fuel but the fuel bowl is half way all the time even if i crank for like 2mins straight?[/img]the fuel filter.is normally only.partially full.
Is the carburetor fuel level at the dot?
Posted on: 2014/3/23 3:47
Re: egi intake
well i crank the engine and it wont start
even if i crank for ages on full throttle wont start
choke works but doesnt raise the idle at all
yes the float level is right on the dot
Posted on: 2014/3/23 3:49
Re: egi intake
Where r u located?
Posted on: 2014/3/23 3:54
Re: egi intake
Is the fuel level at the dot? If its empty it won't start.
Re: egi intake
the fuel level is at the dot always even if i crank for like 2mins its at the same level
i am located in narre warren but its been sitting at my workplace for like 1 month now
Posted on: 2014/3/23 4:13
Re: egi intake
That is good. The only thing the carb needs to do to start the engine is squirt fuel.
So ... does it squirt fuel when you floor the accelerator?
Yes. If it doesn't start, check for spark
No. The carb is bad
Posted on: 2014/3/23 5:47
Re: egi intake
nah it doesnt squirt fuel when i put the accelerator to max,
even if i put my hand on the top of the carbi to stop the air no fuel goes onto my hand and i cant feel it want to squirt out?
do you reckon its a dodgy carburettor
the spark is fine i recently put in electronic ignition and had a auto elec do my wiring
Posted on: 2014/3/23 5:57
Re: egi intake
does it squirt fuel when you floor the accelerator? If Not, the carb is bad
Put the old carb back on even if the idle jumps around so at least you can drive it.
Posted on: 2014/3/23 6:33
« 1 (2) 3 4 »
